My greenhorn knuckle-bonehead maintenance questions
#51
Now I have a question, how do you inspect this without pulling it out? You don't, and the filter minder will actually read very good even after the filter is clogged.
However I wouldn't recommend that anyone continuously remove and inspect their air filter element over and over again to see if it's ruptured or damaged. Every time a filter is disturbed you wind up with some dirt getting into the intake system. The Manufacturers all recommend that a filter be left alone until its time for replacement, either when the restriction gauge shows it is necessary, or at a maximum interval of one year. That's how I've always done it.
If you can't shift it smoothly, you shouldn't be driving it. |
