My greenhorn knuckle-bonehead maintenance questions
I have an '01 Century Class. These are my questions, I'll appreciate insight into any and all of these things:
Air filter- How often do you change yours and do you do anything like blowing it out with an air hose periodically? I once changed my air filter and it seemed my mpg jumped .5 miles. That's a whole lot of money. The new air filter pays for itself if it gives me a .5mpg boost over just 1700 miles. I don't ever want to lose mpg due to an air filter, and that air filter I spoke of wasn't that old. In-cab air filter- OEM ICAF has big gaps in it. Aftermarket ICAFs are fine, no big openings. I have to wipe my dash frequently. Would you suggest I forget the OEMs and just stay with the aftermarket ones? Jakes- Mine are weak, weak, weak. Is there a common problem with jakes? Do you think it's just something electrical that has to be turned up or something mechanical that needs to be repaired? Shocks- How often do you change yours? Coolant hoses- Do you regularly change yours? I was told mine are made of a material that will blow up like a balloon before they break. I was told that's when to change them. Right or wrong? Sealed lubricating systems- My driveshafts have no zerts. I think I have a slack adjuster or two without them. Perhaps even a couple more things (I was serious about knuckle-bonehead). :oops: Think I can have zerts added to my driveshaft? Would you have zerts put in anywhere you can? Nothing I can do about my sealed front hubs is there? Front slack adjuster- Watched a mechanic beat it to death. It had no zert and wouldn't open so he felt no remorse, told me himself I need to change it. The clips are obvious. How do you take the splined part off? Coolant- How often do you change it? |
Cam, you should have a guage which tells you when your air filter needs to be changed. It should be somewhere on are around the filter casing. I prefer to take mine out and visually check it. If it is dirty I change it. If you are simply looking for an interval, you can change it about every other oil change. I used to change mine every time I changed my oil, but I don't think that is always necessary. It depends on how and where you run.
I think aftermarket filters work just fine. The only name brand filters I use are CAT. I think they are better made, but those are for engine filters. If your Jakes are weak, you may want to run an overhead. It should cost somewhere between $200-400. Part of the overhead includes checking and adjusting the Jakes. You can change your shocks about every 2 years. I would probably not do it more frequently than that. I have known of some owners who replace their hoses every year. When they do this they also flush their cooling system. |
Re: My greenhorn knuckle-bonehead maintenance questions
GREAT!!! Here we go...
Thanks Jorlee,
I'm not sure I trust myself to visually inspect my air filter. Obviously when it's pretty gray it needs to be changed. But, is that when it begins to pull the mpg down? I just don't want to wait until I'm already losing mpg to change it. Air filters aren't cheap until you think about fuel, then they are quite cheap. Think I just found out what a 'run an overhead' is. :D Positive on the sealed hubs. Slack adjuster slides right off? I was looking at it and wondering, thought maybe there was something screwed on there or something, maybe not. Maybe I'll just go ahead and do the coolant and the hoses even if they don't need to be done yet. Then at least I'll know they are right. |
One thing though, do not let coolant go to long. You will start to get corrosion problems with your liners. After it eats through your liners, you'll need a rebuild. |
I've got a vacuum gauge on my air filter and changed it at about 200,000 miles. If you don't have one installed, I'd consider it. The thing about any filter, whether air or fluid, is that it's made to trap particulate up to a certain point. Filters actually become more efficient the more clogged they get until they reach the tipping point. This is why a gauge may be money well spent. It will save you from throwing away money needlessly. I think FilterMinder gauges run about $40.
I'd replace your cab filter with any brand you like. However, I'd consider adding a Cab Fresh filter. This is a filter that mounts over your HVAC intake. I've seen a noticeable difference in the amount of dust and outside odor in the cab since I started using these. As an added benefit, anything you can do to reduce debris in the intake will prolong the life of your HVAC system. About $35 at some truckstops and dealers. Ditto on the overhead. I know the OEM shock on my KW only come with a life-expectancy of about 60,000 miles. If I remember right, top model Monroes have a life-cycle of either 100,000 or 150,000 miles. One way to check is to feel your shocks when you stop. If you have a shock that's hot to the touch or warmer than the rest, it's done. Coolant intervals depend on which kind you have. If you have ELC, they're usually made for 400-600,0000 miles provided you add the extender. If you just have regular coolant, everyone I know recommends once a year. |
Cam, if you run in areas where there is a lot of dust, such as El Paso, you may need to change your air filter more frequently than if you run in Middle America. The best thing to do is check it. I check belts and hoses regularly and change them as needed. I usually keep extra belts in the truck in case one breaks. With shocks, if you are short of cash, you can always change them in pairs. I suggest doing it on the same axles at the same time.
Ok, good stuff. Let's see...
>First, I do have a Filter Minder. Mine seemed to indicate 'bad' pretty quicky and at least a couple of mechanics told me you can't rely on them. I've been looking for a better way to make a decision. I'm reading an interval of about 2 months (every other oil change) to 18 months (200,000 miles). This one thing, I don't want to wait until I'm losing mpg to change it. Perhaps I'll just have to get a feel for it. If you 'believe in' Filter Minders let me know, I may need to try it again or even have mine replaced. So it is 'zerk'. I thought it was 'zert' as in short for 'grease insert'. Gonna be a pro someday :D >There's a c clip on the side of the slack adjuster. I'll just starting prying shizzle until I find it and try not to break anything. >Ooooo, bad coolant can cause problems even though there is no overheating. I haven't changed the coolant since I bought the truck so I have no idea what kind it is or how long since it has been changed. Survey says....change it! And hoses while I'm at it. >Well, since the truck didn't come with an owner's manual, I need to lift the bed and start looking for another filter. And yes, Luberfiner makes an aftermarket filter that's better than OEM. One post and I've heard enough to be sold on a cab fresh filter :wink: >The jake problem may not be big $$$ I have an ISX. Engine is running like a top. This 'valve set' won't wreck a good thing, will it? >Changed my front shocks last year but there is oil on one. I'm reading one to two years normally (except in this case, I just have to do it). I'll change them myself if I can muster the torque to get them off and to hold the new ones on properly. Hand tight going to do it? >I like that 'spawn of the devil' :lol: I'm going to get all nasty dirty and crawl around under there looking for blanks. I think it's good to kick this around, one guy does it one way, another does differently. I'm open for rebuttals and anything else you care to share. |
