Headed to Marten
Oh a super 10 it's setup like this
R 3/4 7/8 1/2 5/6 9/10 On a super 10 you shift like ya do on the high side of a 13. you split each gear. I'm trying to explain it to where it makes sense. 9 and 10 automatically shift, but you can program the ecm so you can control the shift yourself from 9 to 10 and vice versa.
I was refering to a coolie carrier as a carrier that hauls cold stuff what do you guys consider a coolier carrier? Ahh yes the new t-660 that i have seen are sweet looking, do you know by chance what they are putting in them as far as a tranny goes. And tk can you explain this point system for me and how does it work.
Thanks Byron
Just another man trying to make a living
Thanks Byron
Since you work for them zipy46 and i just curious at this point but what do you know about their lease program and what trucks can you pick from if you take that route down the road. I'm just asking all the questions i can here so i know what i'm getting into ahead of time.
Thanks Byron
Thanks Byron Do you mean the safety point system where if you use up all your points you're fired ? You start with 12 points and get another one each year you're safe, then if you do stuff wrong each different mishap has a different point value assigned to it. If you totally crash the truck it's like 25 point's so you get really fired. Backing into something is like 4 points. The graph with the point system should be in the handbook somewhere under safety. 8) 8)
http://www.macedoncenterfire.org
So what is a coolie company?
Marten is not a 'Coolie' carrier, not even close. :mrgreen:
Thanks Byron
http://www.macedoncenterfire.org |
