Log Trucks using different Logs
Old 12-28-2006, 05:01 PM
yoopr says:
Plus Myth you really don't understand log hauling which is evident.
Guess you never heard of Log Trucks having Farm Plate exemptions.
I guess that would depend on who was operating the vehicle:
Farm vehicle driver means a person who drives only a commercial motor vehicle that is —
(a) Controlled and operated by a farmer as a private motor carrier of property;
(b) Being used to transport either —
(1) Agricultural products, or
(2) Farm machinery, farm supplies, or both, to or from a farm;
(c) Not being used in the operation of a for-hire motor carrier;
(d) Not carrying hazardous materials of a type or quantity that requires the commercial motor vehicle to be placarded in accordance with §177.823 of this subtitle; and
(e) Being used within 150 air miles of the farmer's farm.
Farmer means any person who operates a farm or is directly involved in the cultivation of land, crops, or livestock which —
(a) Are owned by that person; or
(b) Are under the direct control of that person.
If the farmer owns the vehicle and is operating it then there may be exceptions. If a for hire carrier is running the logs then they are not exempt. :twisted:
yoopr is on a roll and is showing he's not quite as well informed as he thought he was. 8)
I don't know of very many logging companies that own the property and havest the lumber. I do know of logging operations that are hired by mills to haul harvested lumber from the hill to the mill.
FYI, I was a choker setter and landing operator for a lumber mill in my younger days. :wink:
Be safe.
Old 12-28-2006, 05:17 PM
I'm very well "Informed" on Michigan Farm Plated Log trucks
Don't think you are though.
Fed DOT regs don't wash up here when run intra state within the radius.
Farm plated log trucks up don't have to be run or "Owned" by "Farmers"
Old 12-28-2006, 07:07 PM
yoopr off topic says:
Great the next time there's a question about hauling logs intrastate in Michigan I'll keep that in mind. However, the topic was about interstate in TN, GA and KY:
I just started hauling logs in Oct of this year. Since then I have not found anyone that uses a log book, but goes by a time sheet. We drive in 3 states home is AL, drive in GA and TN.
Has anyone heard of this? I have asked if you didn't need a log book to cross state lines, and was told no because Logging is exempt because it comes out of the woods in the natural state and is not changed or processed until you unload it.
Longest haul one way is 120 miles, starts in AL, then GA and TN, and return.
Be safe.
Old 12-29-2006, 02:09 AM
Be safe.
Kind of what I thought Myth :lol:
Old 12-29-2006, 03:23 AM
Wrong-Before you two "Experts" came on to this thread the answer was given to the author of this thread a few times by a few people.
Old 12-29-2006, 05:03 AM
YOOPR: Everyone answered if he was within 150 air mile radius he did not have to log.
Then I told him if he did not need a CDL the regulation is within 150 mile radius and under a certain amount of lbs then you don't have to log.
If he needed a CDL (which I believe you replied "of course you need a cdl to haul logs") then the rule is if you are within 100 air mile radius you do not have to log. He clearly stated he goes over 100 air mile radius in the first message. Therefore he must log. Everyone else is saying if you are within 150 mile radius you are considered local and do not have to log. This is not true if you must carry a CDL and weigh over a certain amount of lbs, which I would assume he is WAY over the wieght limit.
The state thing I did not argue with since I follow federal regulations which over ride (my drivers) the state; the 150 mile radius regulation is not being read carefully! It states NON-CDL drivers within 150 mile radius.
I posted it when I posted the first time.
Again the driver was not being answered correctly!
:roll:
Old 12-29-2006, 05:45 AM
Better read again-I told him IF he crosses a state Line he has to carry a log book
Old 12-29-2006, 08:46 AM
Slider
according to FTC (Federal Transportation Commision) and log book is only required when working outside of a 150 air mile radius of the base termanial.
Slider
nrvsreck
Yes, as far as I understand it, it's a 150-mile air radius. Has nothing to do with crossing state lines. If the longest run in 120 miles, you got nothing to worry about.
yoopr
I've hauled logs up here and if you're within the radius you don't have to log it unless you're crossing a state line.
keep a sheet of your hours though.
What radius is that? 150 miles? No other post to mention any other radius, are you going with the flow or have incomplete post?
Hearing nothing but incorrect responses Papa Rick says:
Hey I really appreciate the info.
Now for another question, do you get the hour sheets from your home state, and if so, do you have to send them back to them every so often.
GMAN offers good advice with:
Most truck stops sell the pocket size handbooks as well as log books. There is a Pilot not too far from you, I believe. They should have them. And I have seen people ticketed for crossing state lines and not logging, even though they were within the 150 mile radius. It is best to check the rule book for yourself.
Sealord ask:
Could cut logs be considered an agricultural product therefore nothing's required other than a time sheet? BOL
Dawn offers:
The 150 miles is only for NON-CDL drivers: So if you do not need a CDL to haul the logs then yes it is 150 mile radius. If you need a CDL to haul logs then if you go outside 100 mile radius you will need to fill out log sheets.
Drivers of property-carrying CMVs which do not require a Commercial Driver's License for operation and who operate within a 150 air-mile radius of their normal work reporting location:
May drive a maximum of 11 hours after coming on duty following 10 or more consecutive hours off duty.
Are not required to keep records-of-duty status (RODS).
May not drive after the 14th hour after coming on duty 5 days a week or after the 16th hour after coming on duty 2 days a week.
Employer must:
Maintain and retain accurate time records for a period of 6 months showing the time the duty period began, ended, and total hours on duty each day in place of RODS.
With a snappy response from yoopr:
Don't know why you repeat answers already given other than your copy and paste.
Dawn replies:
No many said that if he is within 150 miles he does not have to log. They did not specify the fact if he DOES NOT HAVE TO CARRY A CDL HE doesn't have to log it.
If he must have a CDL then his range is 100 miles (just like always)
I do not see where anyone explained that.
I am not sure if Log Haulers need a CDL or not, but I wanted to make sure he knew the fact of 100 miles versus 150 miles. Many people thought they changed the range from 100 to 150 for all local drivers, when in fact they only changed the NON CDL drivers range.
Sorry Yoopr if I repeated, I did not see where it was explained
Again a snappy answer from yoopr:
Of course log haulers have CDL's
eurotrucker says:
With CDL, just make sure you don't go over the working hours, and you
have to carry a DOT physical card when you cross state line.
Chicago1010 confirms Dawn’s post and says:
I reread this post a number of times and I don't think Papa Rick got a complete answer, thou Dawn was very close.
If you have a CDL-A or B license you do not have to log as long as you stay within 100 air miles and you are driving a group A or B vehicle (383.91)
This is, of course if you are operating within this distance of your normal reporting station.
You return to the work reporting and be released from duty within 12 consecutive hours.
You must also maintain your time records.
You are not covered by the non CDL 150 air mile provision
If you have a CDL-A or B or a non CDL license you do not have to log as long as you stay within 150 air miles provided that you are driving a group c vehicle. (under 26,001) This rule applies to property carrying commercial vehicles. I'm not sure if logging falls under this category.
Yoopr, I might add that crossing state lines does not change the rules. Our terminal is about 15 miles from the WI line, 70 from IN line. We always cross these state lines and as long as we are within the radius we only need to keep a time record, no logs.
yoopr forgetting the 100 air mile exception applies to interstate commerce says:
Wrong-Log trucks up here have to carry a log when crossing Wi state line while carrying Logs.
This was a Logging thread case you forgot.
kc0iv offers
In a nutshell anytime you cross a state line you fall under interstate rules.
Chicago1010 offers:
Back to the original question. The driver has a CDL-A license, drives a group A truck and travels 120 miles one direction. By law he needs to log because he is outside the 100 mile radius. The one part I am not sure about is if logging is exempt of this rule.
My only other suggestion is to call your area DOT Safety Reg. office and have them clarify it for you.
Papa Rick says:
Thanks everyone, I will call my area Dot Office and get a better understanding about this.
The reason that I asked this question is:
1. I have talked with a few Log drivers and all of them do not use a log book, but a date/mileage sheet. When I questioned them about this, they all told me that if they travel less than 150 miles they are exempt from the log books, due to being a log hauler????? Never heard of this before, but then again I never hauled logs either for a living.
2. The reason I would like to use the date/mileage sheet if in fact it is legal is because you do not have to watch your time near as close, and on your fuel receipts don't have a time on the mileage sheet, as they do with the log books.
yoopr incorrectly says:
They told you right but remember that even though you though you have your CDL and under Rules and Regs you're gonna be more involved with the State of Alabama's rules and Regs more.
At that time I offer information relevant to when a log book is not required and……
yoopr says:
why all the repeating on this?
Because yoopr and others are still on the 150 air mile radius for non-CDL drivers!
yoopr continues
What is evident is you have your panties in a wad and dislike certain posters.
To ensure yoopr had a good understanding of when there maybe an exception I offered:
Be safe.
Dawn makes a quick comment to which yoopr replies:
Yoopr, FYI, Dawn made the first correct assessment of the situation. However, you continued to post bad information confusing the issue.
FYI, while loggers in Michigan may run farm plates, I doubt they would qualify for the 150 air mile exception from the CDL for farmers. States may allow a vehicle to be farm plated, however, that doesn’t mean the person is a farmer. I can recall a farmer from Idaho who bought a truck from Texas. The farmer was placed OOS at the Cortez scale for no CDL. Another farmer from Oklahoma was sold IRP and fuel permits at the Cortez POE because he did not have apportioned tags or IFTA permit.
License plates are not an automatic exception from the rule. The license plates help the company save money in licensing and do not guarantee exceptions from the FMCSR.
You should hone up on your people skills; your apparent dislike for certain posters reveals your lack of impartial judgment when it comes to poster’s offerings. Your disinformation causes additional posts to ensure the readers are aware of irregularities in your logic.
This post demonstrates that Dawn offered the first correct answer despite yoopr’s claims a correct answer was offered before she came along.
Some have asked why I log on as Myth_Buster instead of JQP. It's because Myth_Buster is appropriate and I am not a regular here as I am on other web sites.
Be safe.
  #39
Old 12-29-2006, 12:22 PM
Default Myth
Thanks for arguing my exact point for me. I am glad someone else can actually see the truth of things around here for a change. I am sorry we have to waste our time on the board here (other places don't do this)
explaining ourselves over and over only to make the original poster confused!
Yoopr: WE are here to help and if I want to post any information that I feel might help 1 driver then I should be able to post it. I don't think you have to wait for the question to appear first.
WE don't always have to use the wording in the book, if they understood that they would not be here asking the question. They are asking for more simple explinations or different ways. I can say something and it may not click and someone use's 1 word different and the person picks it right up. You may go through 20 of those before they actually get it!
When everyone meant the same thing! So the more answers that are "the same, different words" is always great. The different answers (not meaning the same) is what throws everyone off.
I may not be a trucker, but I have allot of sympathy for a trucker and I am always here to help the best I can, and being attacked (yeah attacked as usual) is not a great way to greet someone.
But I always say I can hang with the big dogs and the little dogs! :lol:
WHY DOES THIS BOARD KEEP MAKING YOU SIGN IN AND OUT 20,000 TIMES?? No I didn't do spell check sorry for any error's in advance
  #40
Old 12-29-2006, 01:36 PM
Dawn.... it's all good, both you and GMAN ( and a few others ) helped me understand a couple of things today, and it's much appreciated.
