APU question
Old 07-28-2008, 08:18 AM
I appreciate all the ideas.
I tried to look up specs on the ICT one, but didn't see anything about gph usage. The warranty kinda sucks at 1 yr/2000 hrs.
The powertech one looked pretty good at $5500 self-install...with a nice 3yr warranty.
If he were to get the ICT unit $7500, espar d2 heater $1100, roof a/c $1000, inverter $1000, all the small nickel and dime items he is up in the comfortmaster price range.
Old 07-28-2008, 09:57 AM
Welcome to the wonderful world of trying to save money,......by spending way too much money :wink:
Old 07-28-2008, 10:13 AM
Actually, I said 8 months.
While I'm sure you likely do use it 12 months of the year, that isn't the point. The point is, if you didn't have the APU, would you idle every single night? I know I don't. If it is under 70 degrees and over 30 degrees, I don't idle. I know for a fact that when you first bought the truck, you weren't idling during cold temps (I think you said somewhere around 30 degrees or so, if I remember correctly). That is a night that you would have used no fuel without the APU, but with the APU, you are using fuel.
Yup, your right, 8 months, I read it wrong.
I still sleep with it 30 or so in the cab with the Rigmaster. I put the unit into auto mode when I go to sleep and it turns on at 30 and shuts off at 45. What I meant was during the day I would run it non stop to keep the inside at a very comfortable 72 or so.
So, during the night the unit is off and not using any fuel at all. In the morning I turn it up to 72, hit the on button on my Mr. Coffee and get up about 10 minutes later.
Old 07-28-2008, 10:15 AM
Originally Posted by Doghouse
1.Steve bought a complete package he loves it but it doesn't cool as much as he likes, and the genhead burned out in less than 2000 hrs.
The generator failed like all the other ones in my model year. They are replacing all of them for free.
Also, as with any mechanical piece of equipment, failures are part of the equation and is a fact of life.
Old 07-28-2008, 10:18 AM
Originally Posted by Heavy Duty
notsteve I want you to know that I just can't reach up and push a button to start mine, the control is in the cabinet under the sink, I have to ether set up in bed or pull my leg out from under the covers and use my toe to start or stop the generator.
My God, you poor thing. You are a real trucker unlike Bandit and myself who reach over and push a button unless it's in auto mode, then I do nothing.
BTW Rev, I'm crapping in the cab while I write this!!!!
Old 07-28-2008, 10:19 AM
You mean you've never had anything break on your APU, and you've never had to diagnose why something wasn't working the way it should?
Nope. Except for the generator and that was replaced free.
Old 07-28-2008, 10:20 AM
I like it cold also. I don't use heat unless its around 45. During the winter the propane kept the sleeper at about 70, and it makes no noise at all. I would pick a spot far far away fron the truck stop, for a nice silent night. Same now, if it's under 70, I open my windows. I also park nose in,....and then of couse some driver comes nose in at 3 a.m. with a stinking refer screaming :evil:
Old 07-28-2008, 11:20 AM
pdm
pdm is offline
No alternator on it yet Steve? They've all failed between 500 & 1000 hrs & most of them have had 2 or 3 alternators now. & if you can still thread the caps off the access ports for you're a/c it might be a good idea to tape them up.....that way they will be usable when needed.
You can't fix stupid......
  #39
Old 07-28-2008, 11:25 AM
And the AC you just put on. And the muffler you had put on.
  #40
:shock: do you have a hole in the floor,....or do you use a Home Depot orange bucket.
