Headed to Marten
Old 07-12-2008, 10:05 AM
Originally Posted by midnightlighting
Thats a weird tranny then, all of my ten gears now are manuel. What do you mean by do it wrong?
Lo-1-2-3-4
Flip the button
5-6-7 -8 .....goes in and out of 9 automatically.
If you run up on a steep hill and try to drop from top gear to say
7 ....it will completely unhook.....7-8-9 will not be available....she will coast.
You must let off and let it slow to a speed where
it takes itself from top gear(9) back to 8
(this only occurs when the trans decides to drop a gear...could be 40 mph or 60...its random)
...then you can manually
grab 7th and pull the hill.
personally i would like a good old 10 speed like i am so used to 8)
Old 07-12-2008, 10:34 AM
wow, wonder how long it will take to get the hang out that for me anyways
Just another man trying to make a living
Old 07-12-2008, 10:42 AM
I had it figured out in about half a day
if i can do it...anyone can :mrgreen:
Truck (387) is huge inside....it rides pretty smooth
also the Air Ride trailers float along real well
They also have Freight shakers....Box nose Petes and a few T600's
Old 07-12-2008, 10:50 AM
Are there any volvo 780's in the fleet at all?
Old 07-12-2008, 01:34 PM
TK THE TRUCKER's Avatar
No, they had some Volvo 670's but they are pretty much non-existent now. 8) 8)
Old 07-12-2008, 01:42 PM
Jumbo's Avatar
Default Re: Headed to Marten
[quote="midnightlighting"]I will be starting with them on july 29th. I can say that i'm very glad they called me, yes they are a coolie carrier but i have not heard anything near as bad as some others coolie carries.[/quote
Why would you consider them a coolie carrier?
Old 07-12-2008, 01:49 PM
Lo-1-2-3-4
Flip the button
They have the ECM programmed to not let you downshift too early by giving you no throttle response. It can be kind of random and sometimes you can get by it by putting the pedal to the floor for a second. They have it set up in relation to road speed. Most of the time if you try to shift from 8 to 7 and your going faster than 50 mph you won't get any throttle response until you slow down to 50 or below. If you try and shift from 8 to 7 and your going faster than 45 mph you won't get throttle response until you slow down. Also the 8-9 auto is tied into the cruise control on off switch. The tranny wants to shift between 8-9 at about 60 mph whether your accelerating or slowing down. If your slowing down a little and want it to stay in 9th you have to turn the switch off to lock it in 9th. Same thing if you want to stay in 8th going faster than 60 mph, you have to keep your foot to the floor until you get over 60 mph and then turn the switch off and you can back out of it and it will stay in 8th.
I really hate this transmission setup. I'd rather have a 13 speed, which these 9 speed auto top 2 transmissions kind of are. They can be converted to a 13 speed. I really like the 387 but this transmission make me crazy sometimes. The 387's here are the only ones with 9 speeds. The rest have 10 or 13. 8) 8)
Old 07-12-2008, 01:52 PM
Also, they have just got in some T-660's within the past couple weeks. I like the Kenworth's too even with the narrower cab. 8) 8)
Old 07-12-2008, 01:59 PM
So let me get this straight, instead of a super 10 you have a super 9? Correct?
Old 07-12-2008, 02:07 PM
I couldn't tell you, I've never been stuck with a super 10. If it's anything like this 9 speed I don't want it. I've always had a straight 10, 13 and 18 speed. But it does sound like the super 10 and 9 are similar. Maybe on a super 10 they are counting low as first gear ? 8) 8)
