Old 08-15-2008, 12:23 PM
baileydale's Avatar
Default Log Required ??
Can someone point me to the regs that state when a log is required. I have taken a part time gig running a single axle 22'box refer for a food company. I very seldon have over 5000 lbs and once every two weeks I have about 19500 lbs. Truck is licensed for 36k I believe. I have one run everyother week that exceeds 100 miles (its around 150 )
Thanks
Old 08-15-2008, 01:30 PM
Will you be crossing State Lines? If not intrastate regs apply, check with your State. Is a CDL required to drive the vehicle you will be driving? If not, then no logs are needed.
Shouldn't you be asking your employer what they require?
Old 08-15-2008, 03:14 PM
Rat's Avatar
Rat Rat is offline
I am not positive but I think that the limit is 33,000 lbs.
Old 08-15-2008, 04:41 PM
Uturn2001's Avatar
You will pretty much need to read the entire thing. There are a lot of if various requirements that must be met in a few different situations to allow a RODS not to be required.
Old 08-15-2008, 05:35 PM
marylandkw's Avatar
Default Re: Log Required ??
Anything over 26,001 pounds requires a CDL.
Old 08-16-2008, 03:02 PM
He doesn't seem to be very sure of what he's driving, that's why I asked. When you end the sentence with the words "I believe" I think that means he doesn't KNOW for sure.
Old 08-17-2008, 02:44 PM
It isn't the weight of the cargo but the gross vehicle weight rating (GVWR) of the truck that determines whether you need to have a CDL. If you drive a truck that has a GVWR of 33,000 pounds, you need to have a CDL. Go to the fmcsa website and read the requirements.
Old 08-17-2008, 04:37 PM
thebaldeagle655's Avatar
Actually GMAN, you are right but wrong, part 390 under definitions states
Commercial motor vehicle means any self-propelled or towed motor vehicle used on a highway in interstate commerce to transport passengers or property when the vehicle—
(1) Has a gross vehicle weight rating or gross combination weight rating, or gross vehicle weight or gross combination weight, of 4,536 kg (10,001 pounds) or more, whichever is greater; or
Since his question was about a log book, not a CDL, yes he needs a log book.
No CDL required for less than 26,001 lbs BUT, if you cross state lines and GVRW is over 10,001 COMBINAtION, you need to run a Log Book, have a DOT #, and insurance. Don't really know about the medical card or drug testing though.
I have 1st hand knowledge about this one, got popped by DOT with a 3/4 ton pickup pulling a gooseneck trailer crossing state lines!
Old 08-18-2008, 11:12 PM
HWD's Avatar
HWD HWD is offline
To split hairs even further, you are required to have a CDL if you're placarded for hazmat - regardless of GVWR.
Old 08-25-2008, 12:39 AM
rigidsporty's Avatar
I was in food service delivery over a year ago (my back still hurts) driving trucks that required a Class A CDL (see pic below), rarely going past the 100 mile limit, and occasionally crossing state lines... but the only time I was required to fill out a logbook was when I worked over 12 hours (which means I filled one out a lot!)
