Originally Posted by JB Express Transport
Thanks for the tip Scottt, I saw that truck a while ago,Its the white Pete located in Tifton Ga. I think this is its 4th-5th time listed...$14,000 which sounded good for a shell to work with...But I dont have much knowledge on an overhaul & front end work. I woud probably have a Pete dealer do the work and hope they didnt stick it up my a## too much. No matter what I look at other than a Pete...I keep migrating back to Peterbilt. So I'm locked onto the Pete 387...I'm just sitting in neutral waiting to find that perfect deal...Patience is one of my strong suits...so I'll wait it out till something shows up somewhere.
Keep an eye out for a Pete 387 Auto...Thanks Again !
I wouldn't pay over $7K for the Pete in GA.
If I had the engine rebuilt I would have Cummins do it, not a Pete dealership. Engine rebuild around $18K and frontend around $2K.
If you want a project I have a 03 387 465hp ISX with autoshift. Has oil in the water and water ooozzzing out of the head where it bolts to the block. (head gasket) Front cover leaks oil, Still runs good. Body has some battle wounds. $5k
I found another engine to put in it for $5750 which I am going to do in the spring if nobody wants it like it is. The 06 Freightliner I bought isn't half the truck as my Pete is.
