power inverter
Old 07-06-2007, 10:48 AM
Blind Driver's Avatar
Many companies won't allow inverters because they can be hard on the batteries.
I used the microwave in the truck stops. Gotta go in to pee anyway :wink:
Old 07-06-2007, 10:51 AM
Originally Posted by honestashol
Originally Posted by Mattangcobra
...run the other side out the side door of your sleeper to the cat walk if you have a battery connection back there.
Are additional battery connections common? I know nothing about tractors, but it seems that's an extra most companies wouldn't pay for.
On tractors with the "tool box" style battery box that hangs on the rails it is fairly common for them to have a positive stud on the box itself. It is there to make jump starting a little easier so you do not have to take the cover off the box.
Old 07-06-2007, 11:27 AM
Originally Posted by allan5oh
Originally Posted by Skywalker
DO NOT try to power it with a plug-in inverter....you will burn the tractor to the ground.
Or just blow the fuse for the cig lighter repeatedly?
You could just replace the fuse with a 10 gauge wire...That should solve the problem..
It has always been my belief that a man should do his best, regardless of how much he receives for his services, or the number of people he may be serving or the class of people served.
Napoleon Hill
Old 07-06-2007, 02:41 PM
I've ran nothing but reefer. Every truck I have had has a positive and negitive stud behind the sleeper to junp the reefer off if the batt. or alt. goes out. DO NOT REPLACE YOUR FUSES WITH BIGGER FUSES OR 10 GUAGE WIRE You WILL burn your truck down!!!!!!
Has everyone forgotten how to be COURTEOUS.
If you've forgot, it means.
respect for and consideration of others
Old 07-06-2007, 02:46 PM
Sorry for my last post I didn't relise you were a firefighter. You knew what I said before I said it. About the fuses and wire. But some of the others might not.
Old 07-06-2007, 03:58 PM
yeah ill just stick to the 400 watt and use other methods. Hell i can get a camp stove and set it up OUTSIDE THE TRUCK and warm up stuff to. The wiring deal is is very stupid. Yes I am a Vol FF and I have seen idiots do stupid stuff with the wiring in there cars
Old 07-08-2007, 08:40 AM
I have a lunch box oven bought it for $16 a long time ago still works well it plugs into cig lighter,good for soup, ravioli,chicken & dumplins or other can foods, but takes 30+ min to heat, use foil mini loaf pans so no clean up heat and eat out same pan and toss, can also heat water for instant coffee :sad: in a pinch, or heat hot dogs. bol to ya
CJ
Old 07-08-2007, 10:46 AM
how many watts is a dorm size fridge?
Old 07-08-2007, 12:41 PM
While they require only about 50-100 watts to run, the compressor startup draws a lot more power than a 400 watt inverter can handle.
Old 07-08-2007, 12:53 PM
Skywalker's Avatar
Lets see now.....
Thats like putting a penny in an old style 110V fuse box.....and lots of houses burnt down because of it.... :shock:
If I absolutely couldn't hook up an inverter directly to the batteries, then I would measure the distance from where the inverter will be used to the positive stud on the battery box (Internationals) or under the hood (KW's)
then double the distance, consult with an expert as to the proper gage of cable to be used and hook it up when needed, and disconnect when done.
NEVER UNDER ANY CIRCUMSTANCES USE A LARGE INVERTER WITHOUT HAVING THE TRUCK RUNNING AT A HIGH IDLE.....YOU WILL EAT THE BATTERIES QUICKLY AND HAVE TO GET A JUMP START!!
Forrest Gump was right....and some people literally strive to prove it.....everyday. Strive not to be one of "them".... And "lemmings" are a dime a dozen!
Remember: The "truth WILL set you free"! If it doesn't "set you free"....."it will trap you in the cesspool of your own design".
They lost my original "avatar"....oh well.
