sticky clutch.. 2000 classic xl
Old 08-21-2013, 01:16 PM
Default sticky clutch.. 2000 classic xl
if anyone can help me would be great.. i'm lost on this one. my dad purchased a 2000 classic XL. truck has sat for about 3 years. the clutch pedal sticks to the floor then comes up. I tried lubing the linkage every where but its still doing it. what do you think?
Old 08-22-2013, 07:20 AM
Maniac's Avatar
Did you grease the cross shaft on both sides of the bell housing?
Also is there a return spring? Or supposed to be?
Old 08-22-2013, 07:19 PM
there is a return spring on it. i did not do the cross shaft. the truck was just serviced at TA last week. guess i'm getting under it tomorrow.
tired of hearing everyone telling me the driver is "snapping" the clutch out on it.. good thing he told us the clutch was sticking.... (he didnt... had to find out the hard way..)
Old 08-23-2013, 01:42 AM
chris1's Avatar
If it's an "easy pedal" the forks may be binding. That was a big problem with them.
Old 08-23-2013, 04:19 AM
i dont know if its a easy. it was replaced but a while ago. all the records were lost.
is there a way to check for the forks?
Old 08-23-2013, 09:06 AM
chris1's Avatar
Pull the inspection cover. Usually just one or two fingers will not spring back. Eventually they break.
