Clutch replacement on Ford LNT9000 semi tractor.
Old 11-17-2012, 03:38 PM
Default Clutch replacement on Ford LNT9000 semi tractor.
I have a Ford LNT9000 semi tractor and the clutch is showing signs of wear, such as jerkiness, slow acceleration when heavily loaded, with RPM climbing and speed not increasing, etc.
The engine is, if I recall correctly, is Cummins N14 and the transmission is Eaton Fuller 10 speed.
My question is how easy it is to replace a clutch and have the flywheel resurfaced?
We have a forklift and a building with an even floor.
Also what would be a good source of replacement clutches?
Thanks!
i
Old 11-18-2012, 12:58 AM
Maniac's Avatar
Just like any other clutch job, around 12 hours if the guy can cut the flywheel in a timely manor, the truck dealer is where I but clutches
Old 11-18-2012, 04:12 AM
And, by the way, do I need any special tools besides wrenches, jack, forklift etc? Like special purpose alignment tools and so on?
Old 11-18-2012, 04:43 AM
Maniac's Avatar
No not really, i usually put the clutch on the input shaft and put the trans in, then tighten the clutch bolts thru the little opening, sounds like a lot of work, but it beats trying to get the trans into a misaligned clutch
Old 11-18-2012, 04:58 AM
This is a great idea!
One more question, I looked up transmission jacks (I do not have one currently). They seem to have different capacities.
Anyone has an idea what capacity transmission jack I need for a heavy Class 8 truck transmission?
Thanks
Old 11-18-2012, 08:20 AM
Maniac's Avatar
I can't remember the weight of my 18 speed, I wil estimate around 1000 pounds, probably high, but better safe than sorry, also I remove the clutch the same way, undo the bolts thru the hole and pull the trans back with the clutch still on it
Old 11-19-2012, 02:43 PM
Maniac, thanks a lot. Do you happen to know how much would it cost to replace the clutch and motor seal at a transmission shop? Thank you!
Old 11-19-2012, 03:31 PM
I just replaced my clutch when I put in a new transmission. I think that I paid less than $600 for the new clutch at a local clutch shop. Like Maniac stated, it is about a 12 hour job to pull the transmission and change out the clutch.
Old 11-20-2012, 06:36 AM
Maniac's Avatar
Rear engine seal on a Cummins, not sure, on a Cat the seal is around $75.00 and once the flywheel is off, its right there.
Last clutch I bought was around $800.00, but I use the big 2500 ft lb easy pedal, amd like I said, 12 hours easy, could even be more on some trucks
Old 01-16-2013, 11:18 PM
I think that this is same like other trucks. I am not confirm.
Forklift
