Cruise control
Old 01-17-2013, 04:13 PM
freebirdrfd's Avatar
Default Cruise control
T-2000, when I turn the cruise on, the dash shows that its on and set for whatever speed, but for some reason it does not work. Where should I start?
Old 01-18-2013, 12:28 AM
jakes work..... brake lights work... had a freightliner do that and it was a bad pin on the plug going in to the ecm..... the trucks ecm thought i had my foot clutch
Old 01-18-2013, 12:49 AM
There should be a switch attached to your clutch linkage, chaeck and make sure that it is fully released.
Old 01-18-2013, 01:10 AM
solo379's Avatar
Clutch, or brakes...it should be a good start.
Old 01-18-2013, 02:57 AM
Now that you mentioned the jake, it will be off but yet still sound like its on sometimes between the first couple of gears
Old 01-19-2013, 03:35 PM
GPC
GPC is offline
Had the same problem on my W900 neither the cruise or the jake would work. Ended up being the clutch pedal wasn't coming all the way up. Got that fixed and now it works fine.
Old 01-20-2013, 05:46 AM
With the Cascadia I drive, I can leave a rest area without ever touching the brakes and the cruise will not set speed until I touch the brakes at least once.
Old 01-20-2013, 08:06 AM
I also had a truck i could not get the cruise on and they told me you have to put your foot on the brake before you release the park brake and then the comp. will recognize the cruise i hope t his helps.
