Differential not locking!
Old 03-23-2009, 04:29 PM
matcat's Avatar
Originally Posted by allan5oh
No I meant disable the front brakes from working at all by backing them off. Then pull OUT the yellow button and leave it out.
This forces the torque to go to the front axle, since the rear is locked via the brakes. Traction control systems do this in a different manner.
Not quite sure how you would do that. I just built the air up to 125 psi, shut the truck off, and it dropped to 100 psi in about a minute.
My Trucking Blog: http://matcattruckin.blogspot.com/
Website I am making for drivers: http://www.4thedriver.com
As I sit looking all around,
Confusion and uncertainty is all I found.
The answers are there,
But I do not know where.
Optimistic and hopeful dreams,
Are all I have so it seems.
The future I do not know,
So all I can do is take it slow.
But I do know it will work out,
So I wait and watch without a doubt
Old 03-25-2009, 01:11 PM
Jumbo's Avatar
Take off the air line that leads to the lock and see if air comes out when you flip the switch. It is possible the the lock is frozen from non use.
Old 03-25-2009, 04:36 PM
matcat's Avatar
I'll try that next time im sitting during the day. Its a pain to find it though with the catwalk that covers the entire frame over it, probably would have to drop the trailer to get at it.
Old 03-26-2009, 03:51 PM
heavyhaulerss's Avatar
the lever in the dash that locks the pdl may be leaking. take the 2 screws out & spray some soapy water on the air line going to it, then flip the switch back & forth & see if it leaks.
