International Dashboard Problem Fix
A while back someone was talking about the epidemic of cracked and broken dashboard framework in the International 5000 Paystars and the 9000 series.
This happens in the area around the parking brake and trailer valve, the symptoms are that the dash tends to "push in" whenever the parking brake or trailer knobs are pushed in. Reportedly International has a factory kit to remedy this, but we have not been able to obtain said kit. Here are some photos of a brace that I made up today to repair one of those broken dashboards. Hopefully this will help someone out there who is having the same problem: Photo of brace on workbench: ![]() Dashboard with outer panel removed before installation of brace: ![]() Dashboard with brace installed: ![]() Dashboard after reassembly - no external evidence of modification (except that the parking brake and trailer supply valve are now supported so the dashboard doesn't collapse when you push the knobs in:
Nice work. I wish I had thought about that when I had my cornbinder. Of course I wish I could weld also...but you can't win every battle.
Paranoia is nothing more than the pathological habit of paying close attention. All ideas in this communication are sole property of the voices in my head. (C) 2006, "The Voices" (TM) |
