Originally Posted by TK THE TRUCKER
What kind of condition is the radiator in ? Is it all corroded or is clean and intact. Is there anything blocking airflow to the radiator like license plates and Christmas wreaths :lol: ? How's the fan clutch, do you hear the fan cycling properly ? Sounds like they do need to refund your money 8) 8)
Easy way to check airflow through the radiator..hang a T-shirt on a hanger, in front of it, then idle up the engine as far as you can, with fan on. If airflow is stron the T-shirt should be sucked up into the grill. if airflow is bad...it'll be hanging there flapping.
Was shown that by the International dealer in Portland OR last summer.
ops: Had spent over $3,400 on the friggin engine up to that point...for a plugged charge air cooler.
