t600/t800 defrost
The heater/AC/defrost fan doesn't seem to blow as much air as it should in my '95 T600 and my '98 T800. The temp is fine, it just needs more air. I need to have the def on full in order to keep the fog and ice off, meanwhile the side windows fog up and my feet freeze.
Is this a common thing?
Is this a common thing? If the airflow is truly too low, it is most likely caused by the cabin air filter for the HVAC system.
Yes, in KW's anyway, driver side fogs up bad on my all the W9's I have had, there is no cabin filter that I know of, only thing you can check is that all the vent hoses are attached and not kinked behind the dash. I have the passenger side floor heat vent blocked off, so I can get more heat on my side, I keep the center vents on the dash closed in the winter, and the side ones aimed at the side windows.
Yes, in KW's anyway, driver side fogs up bad on my all the W9's I have had, there is no cabin filter that I know of, I've had lots of customers that "didn't know they had one"... it's used to filter incoming air before it clogs your a/c evaporator.
Yes, in KW's anyway, driver side fogs up bad on my all the W9's I have had, there is no cabin filter that I know of, I've had lots of customers that "didn't know they had one"... it's used to filter incoming air before it clogs your a/c evaporator. Come on Bob! Don't keep us in suspense......where's it located? So the poor guy can at least pull that dirty clogged one--get some heat going before he freezes his toes and other parts off. |
