Oil consumption
Old 12-09-2007, 07:36 AM
heavyhaulerss's Avatar
if replacing one injector it is wise to replace all along with the o-rings & a overhead will have to be done. price will be apprx $2300-$2500 total.
Old 12-09-2007, 07:38 AM
Bandit102's Avatar
In the absence of any driveability/performance issues and any obvious physical injector failures, I'd simply replace the o-rings and do the overhead.
Old 12-09-2007, 07:57 AM
what is the mileage ? if it is high & injectors are original, then you may want to replace if not you may want to just replace -o- rings..
Old 12-09-2007, 08:17 AM
The engine is a 2001 and only has 150,000 miles on it. I have owned the truck since 2003. It had 70,000 miles on it when i bought it. I have never touched the injectors. It has used oil like this1 gallon every 600 miles) since i have had it. I really do not have anything to compare it to but to me, the power level IS NOT where i think it should be.
Should i have this work accomplished by a shop or can i do this myself?
Hate to sound dumb abt. this but, i am. What does the term overhead mean?
Old 12-09-2007, 09:03 AM
Originally Posted by Ronm
So, what is the diagnosis from the photos?
:lol: Yea, i poured them back into the tank. That would be nasty. :lol:
What would the reccomended repair be? Is this something that i could do myself. I know they are not the same but, i do all the work on our race cars.
the next step is to pull all 6 injectors and re o-ring them ... if you're familiar with HEUI engines, you could do it yourself
Old 12-09-2007, 09:37 AM
I'm a little familir with them. I have never pulled a injector before. Guess i should have someone else do it right?
Old 12-09-2007, 11:48 AM
check your tanks for 'black fuel'
_________________
what would this indicate ? thank you..
An o-ring(s) on the fuel injector body separates the fuel supply system from the high pressure oil system. Because the oil system is at a much higher pressure , if the o-ring leaks ; oil in the fuel.
Old 12-09-2007, 03:12 PM
Bandit102's Avatar
Its not a diffifult job but if you aren't comfortable getting into it, don't even start. Just make sure you don't let some bozo talk you in to replacing the injectors over this.
Old 12-10-2007, 01:26 AM
I know the injectors are preasure tested to see if they are in spec. Is there anyway to do just a visual or "at home" bench test to see if the injectors are sat? How often do injectors go bad and what is usually the cause?
I appreciate all the info you guys have provided me. I am sure it has been said many times over but "i sure wish i had found this site sooner"
Old 12-10-2007, 08:29 AM
Well, guess what guys. I could not see inside the tank so i drew a sample. These bottles hold abt. 10 ozs. The one on the right obviouslly came from the tank. The one on the left is fuel i purchased in a can and brought home. So, i am guessing that i have an injector problem. I just filled the tanks abt. 90 miles before taking this sample. I had a quarter of a tank when i filled. Would it be the seals/o-rings around the injectors? Also, would this cause any power loss? Hope you guys do not mind all the questions.
How do you add the pic to your post ??
