Trailer hand brake
Originally Posted by RockyMtnProDriver
Originally Posted by bob h
In the case of the tractors that I tested, the primary from the foot valve and primary from the hand valve both go to a double-check (supply ports). Delivery from that dc goes to a supply port for a "blend air double-check", and the other supply connection comes from the treadle sec delivery. Delivery from that second dc supplies the service (control) signal at the tp valve. ... if that makes sense ?!? IE - the trailer service signal does use blend air... but, NOT from the hand valve... *"supply to the hand valve"* was the original question There would be another two way check valve that would connect that signal and the signal from the hand valve which would then give you a signal from both the foot valve and the hand valve, depending on which one you use, or if you where using both, in which ever one which had the highest PSI would then be the signal going to the Tractor Protection valve. In other words, if you where putting 40 PSI with the foot valve and 60 PSI with the hand valve, then you would have 40 PSI going to the service brakes on the tractor, and 60 PSI going to the service brakes on the trailer. Or if you where putting 40 psi with the hand valve, and 60 PSI with the foot valve, then you would have 60 PSI going to the service brakes on the trailer and the tractor. Now of course, you need supply air going to the back of the hand valve. This is where we started the conversation. On my air board, I use blended air, but as we have seen, it can be blended air, secondary air, or primary air. As I said, I don't understand why Blended air is not used always. Because if it is, and you lose either tank, you would always have supply air to the back of the hand valve and you would need to lose both tanks to lose application air to the trailer brakes. Because the trailer still has service brakes with or without the hand valve.
Because the trailer still has service brakes with or without the hand valve. poor dumb limited experience driver's service line comes loose from glad hand or gets cut(what ever) he's rolling down steep hill, loosing air( but can't figure out WHY) he's pulling down hard on that hand valve----got his foot on the brake pedal. Do you really want him to bleed off all his air from both tanks?
Because the trailer still has service brakes with or without the hand valve. poor dumb limited experience driver's service line comes loose from glad hand or gets cut(what ever) he's rolling down steep hill, loosing air( but can't figure out WHY) he's pulling down hard on that hand valve----got his foot on the brake pedal. Do you really want him to bleed off all his air from both tanks? If he is going to fast, then brake fade will occur and he wont have any brakes anyway. But, that does not take away from the fact that you can have it plumbed into Blended, Primary or secondary. It is almost as if they are saying, it does not matter. I have racked my brain for it, but cannot come with an answer that applies. Except, that a hand valve is not a necessary part of an air brake system, so as an add on, no thought was put into how, or probably more realistically, no thought was put into why. There is a guy I am going to ask, he might know.
but the spring brakes on the trailer won't apply until the air pressure in the trailer tank is depleted....
At 40 to 20 your dash valves will dynamite and on they come. BUT.....if this is happening at speed, then they are going to get hot, brake fade will start to effect the linings ability to contact the drums and you wont have brakes anyway. This assuming you are still going down that steep grade you where talking about. Flat ground, if the ground is dry, you will probably just eventually stop. If it is wet, your tractor could jackknife if the tractor springs come on harder than the trailer, or the trailer could swing out if the trailer springs come on harder than the tractors.
Because the trailer still has service brakes with or without the hand valve. poor dumb limited experience driver's service line comes loose from glad hand or gets cut(what ever) he's rolling down steep hill, loosing air( but can't figure out WHY) he's pulling down hard on that hand valve----got his foot on the brake pedal. Do you really want him to bleed off all his air from both tanks? It is impossible to deplete the tractor air supply with an air leak from behind the tractor... that is what the tractor protection valve is for.
Because the trailer still has service brakes with or without the hand valve. poor dumb limited experience driver's service line comes loose from glad hand or gets cut(what ever) he's rolling down steep hill, loosing air( but can't figure out WHY) he's pulling down hard on that hand valve----got his foot on the brake pedal. Do you really want him to bleed off all his air from both tanks? It is impossible to deplete the tractor air supply with an air leak from behind the tractor... that is what the tractor protection valve is for. preform the following experiment: with the tractor running, set the tractor brakes, supply air to your trailer as if you were ROLLING----now, take your seat belt and wrap around the hand valve like you would if you were checking your trailer brake lights---now go disconnect the blue- service line---and watch your air tanks deplete---- now, in my case--only the secondary tank empties out---- the trailer brakes will not dynamite unless the air is emptied from the trailer supply tank---which won't happen because there's no signal air to the control valve back there.
It is impossible to deplete the tractor air supply with an air leak from behind the tractor... that is what the tractor protection valve is for. preform the following experiment: with the tractor running, set the tractor brakes, supply air to your trailer as if you were ROLLING----now, take your seat belt and wrap around the hand valve like you would if you were checking your trailer brake lights---now go disconnect the blue- service line---and watch your air tanks deplete---- now, in my case--only the secondary tank empties out---- the trailer brakes will not dynamite unless the air is emptied from the trailer supply tank---which won't happen because there's no signal air to the control valve back there. With the hand valve getting is supply from Blended Air, and with the service line disconnected to the trailer, by making a brake application with the hand valve, both Primary air and Secondary air tanks depleted, Trailer tank did not deplete, and trailer dynamited when it got down to about 50 PSI. With the hand valve getiing its supply from the Secondary tank, secondary tank depleted and trailer did NOT dynamite. With the hand valve getting its supply from the Primary tank, Primary tank depleted and trailer did NOT dynamite.
Well bob's only part wrong,
the tractor protection valve will only engage when there's total air loss---from both tanks--when they both near 65pounds or so--that's when the protection valve on my truck kicks in-- I don't believe I have a way to drain just my primary so it could be triggered by it alone.(maybe) Trailer brakes dynamiting and protection valve engaging are 2 different things. here's another experiment: (1)park your truck on a hillside- engage the brakes--then supply air to the trailer brakes to dis-engage them(see-not holding in red button as that would damage it) (2) disconnect the blue service line--- FIRST( SIGNAL AIR ) (3) NOW disconnect the RED supply line- tractor protection valve should pop when air drops to around 65psi (4) get in the truck, and release the tractor brakes----get ready to cover the foot brake---your trailer spring brakes shouldn't have engaged( there's a protection valve on the trailer system just like the tractor--- very unsafe to have brakes lock up while rolling due to severed air line. this is the reason WHY I can't understand why anyone would want an Aux trailer braking system to feed off both your primary & secondary tanks--- that secondary is a (reserve)---if you were to loose brakes on the trailer---by way of broken service line, etc You'd want to keep as much air in the primary as possible---sure, every time you step on the foot brake you'd be losing air from both----but why would you want to compound the problem by piping air from Both tanks to a trailer brake via a hand valve? what ADVANTAGE would it really serve. |
