LED Turn signal problems
Old 03-18-2007, 06:56 AM
JBA
JBA is offline
Default LED Turn signal problems
I just replaced the old box type front turn signal/running lights on my KW T800 with new l.e.d types. The installation went fine. My problem is that the left and right turn signals front and rear will not work. The 4-ways work fine and the running lights work. Could this be the flasher? I wasn't sure since the 4-ways work. Thanks for any help. 8)
Old 03-18-2007, 07:12 AM
Kranky's Avatar
LED's don't draw much current compared to regular incandescent bulbs.
The draw may not be enough to make the flasher cycle properly.
With the 4 ways on the total current draw may be enough to cycle the flasher.
Old 03-18-2007, 07:17 AM
JBA
JBA is offline
That's true. Is there a flasher or something that would correct this problem? Thanks for the reply!
Old 03-18-2007, 09:04 AM
Kranky's Avatar
Try a Grote #44891 flasher - it's designed to work with LED lights.
(that's the 2 pin style which I would assume your truck has, however if you have the 3 pin flasher it would be a Grote # 44890)
Old 03-18-2007, 10:40 AM
Bobby's Avatar
Depends on how new the truck is ? My 01 KW doesn't have a flasher like older trucks. I'm not sure how it flashes ?? Solid state ?
I also replaced my square type fender lights with some I got off of ebay. I was real happy with them.
I had to wire them in ( not plug in) but I didn't have any problems.
The rears are LED also. Their a good safety feature.
Edit: my truck does have 4 rear lights, two oval up above and the grote style square ones with the back up lights built in, .their a new Led style too.
I do get a weird double flash from the fender lights and the ovals in the rear. It's a short flash that's instantly followed by a regular flash, it didn't do that before, But it's kinda cool and gets your attention.
Old 03-18-2007, 11:04 AM
JBA
JBA is offline
Thanks for the info. I purchased a 2 pin flasher online that should do the trick.
Old 03-18-2007, 11:11 AM
JBA
JBA is offline
The flasher should be located under the dash to the left of the steering wheel column in a pull down compartment (2 screws) in front of the fuse panel. I spoke with a guy who had the same problem (no signals, Quick blinking) and he said that a led type flasher would clear things up for me. I'll let you know how it works.
Old 03-18-2007, 12:44 PM
Bobby's Avatar
Thanks, I'll check for a flasher in that location.
What year is your KW ?
Old 03-18-2007, 12:49 PM
JBA
JBA is offline
I own a 2001 t800
Old 03-25-2007, 02:12 AM
My guess is that you wired the new lights up wrong. You can wire those lights up so you get different results as in one thing working and something else doesn't. I just went through this on my truck replacing the directional lights.
If your 4-ways work then your flasher is good.
