5th wheel adjustment?
Old 03-08-2007, 02:03 PM
Default 5th wheel adjustment?
Can I adjust the fifth wheels tightness around the kingpin? Seems like there is a little play, and you can feel the king pin slide around. Truck is a 04 mack vision, Thanks
Old 03-09-2007, 12:34 AM
Default Re: 5th wheel adjustment?
if you need to ask... tha answer is NO
but, a tech trained to do so can.
not pretty when that procedure goes awry
Old 03-09-2007, 05:02 AM
I think Steve Booth had the same problem with his 5th wheel. Check his post.
Old 03-11-2007, 12:53 AM
There should be a bolt you can adjust. If it can no longer be adjusted, then you may need to either get a new fifth wheel or have the old one rebuilt. I would start by trying to adjust it.
Old 03-11-2007, 03:32 AM
Part Time Dweller's Avatar
Find out what 5th wheel you have, then go to the MFG's web site. You should be able to download the info on how to properly adjust the jaws. If not, seek professional help, as improper adjustment could lead to premature dropping of the trailer in a most inopportune moment. :lol:
Old 03-12-2007, 10:35 PM
My 5th wheel was loose and they tightened it up all the way but still no good. I had to get it rebuilt and now it's great.
