Adding Tilt steering???
I have a '95 FLD120 that I plan on trying to remount the steering column to a better angle this spring - I think I just need to machine up some spacers or ? I'll let you all know how it goes 8) .
Originally Posted by Slickwillie
Anyone know how involved and pricey it would be to add Tilt to a 05 Freightliner Century??? :?:
Be careful about changing anything connected with steering or brakes away from the stock setup.
If there's ever a crash, the lawyers will use that to hang you
Whenever I'm in Portland Oregon, I go shopping at the surplus section at Portland Freightliner where they sell "leftover" parts from the factory. I've seen bins full of the factory tilt/tele steering coluums out there. Might want to give them a call. Other than that, truck salvage yard would be your best bet.
Never paid attention to the price, but they're pretty reasonable. Trick is finding the right item for your application.
I can't beleive that tilt is optional. Teamsters contracts requires it. Not to sound stupid, but are you sure yours doesn't have it?(The unlock mechanism is air operated. There's a button on the floor that you press with your left foot. It's up high, on the firewall you might say- look for it from the ground.)
Trucking is the worst #@%?>&# business you ever saw. I just wish I didn't like it so much... |
