Smith system says.
Driving is a complex task that requires drivers to deal with constantly changing variables skillfully and consistently. Remaining collision free, year after year, has much more to do with skill than luck.
A skill is an ability, usually learned and acquired through training, to perform actions which achieve a desired outcome.
Luck can be defined as a chance happening, or as that which happens beyond a person's control
Bullets hit their target long before the victum can hear the sound. Lightening :idea: is seen long before you hear the thunder........ :!:
:idea: .................................................. .. :!:
Speed of light
:idea: In metric units, c is exactly 299,792,458 metres per second
Speed of sound :!:
At sea level, at a temperature of 21 °C (70 °F) and under normal atmospheric conditions, the speed of sound is 344 m/s (770 mph or 1238 km/h).
Light is 871,489.7035 Times faster than sound. The sound is on or off you can direct the light. I have reached for the air horn in the past and with adrenelin flowing ripped the cable off of the air valve.
In this case I was traveling 35 mph as the car approached the intersection. The car not intending to stop at the stop sign expecting no traffic due to the late hour and the remoteness of the area. Can you blame him he has made same turn at same time every day never encountered opposition so he wishes to proceed through the intersection as usual and make a right hand turn instinctively he looks right first about this time I hit him with the spot light it is at this time he realises the light shadow and applies the brake before he can make it through the intersection and before he looks to his left where I am approaching the intersection. When you see such a light generated from that heigth or shadow from that light the first thing you think it is a cop so the initial response is one of submission/identification rather than one of a challenge/pull out.
Evedently he cared and valued his life he applied brakes and stopped just shy of a collision. After cleaning out his draws if he wants to prodceed with road rage it is his option. He apparantly realized he cheated death or was taunting death and hopefully will in the future take more percautions.
Traffic crashes come at an enormous cost to society, Mineta noted. NHTSA estimates show that highway crashes cost society $230.6 billion a year, about $820 per person.
:mrgreen: Many of the safety problems may date back to as early as 1955 with the birth of the interstate system and the integration into the system of previously constructedhighways that were designed for maximum speed limits of 60 mph, the NTSB said.
This quote :mrgreen: proves the interstates need more warning something faster read the article it said the motor coach driver needed time. I use light the fastest medium known to man.
http://www.ntsb.gov/events/journalis...over_60mph.txt
