Low oil pressure in N14 Cummins
Old 04-22-2006, 04:43 AM
Mountain Flyer's Avatar
Thanks Big Al, I will pass that on to the mechanics when I have it looked at. IT is staying about the same; running 28# or so at normal road temps and RPM's., and has been that way for the 15,000 miles I have put on it so far. I found some good Cummins mechanics at a shop in Twin Falls, ID;;;; just have to make time to schedule it in for them to check it out. Kind of afraid what they will find so am kinda not in a big hurry if you know what I mean... :roll:
"It is not the critic who counts,
not the man who points out how the strong man stumbled,
or where the doer of deeds could have done better.
The credit belongs to the man who is actually in the arena;
whose face is marred by the dust and sweat and blood;
who strives valiantly; who errs and comes short again and again;
who knows the great enthusiasms,
the great devotions and spends himself in a worthy course;
who at the best, knows in the end the triumph of high achievement,
and who, at worst, if he fails, at least fails while daring greatly;
so that his place shall never be with those cold and timid souls
who know neither victory or defeat."
Theodore Roosevelt
Old 05-07-2006, 05:39 AM
Big Al and One were both on target... had the truck checked Friday; had one piston cooler that they replaced and they also took the piston out of the oil pump and cleaned it up. The combination bumped my oil pressure from the low 20's to almost 30 p.s.i.. The mechanic said for Cummins about 30# or a little over is average anyhow, so I can sleep much better now... 8) The truck runs well otherwise and has good power; doesn't smoke, and what oil it uses it mostly leaks out, rather than burns from what I can tell.
Anyhow, thanks boys for the suggestions.
Theodore Roosevelt
Old 06-24-2006, 06:06 PM
had the samw thing in my western star 13psi at idle and 31 at 1500 i also thought this was low for a motor with under 200,000 on an inframe when i took it to the dealer they manually checked and showed me the cummings specs for the n14 in there book and 10 psi at idle is within spec and 30 psi at 1400 so you are right were you are supposed to be :P
Old 06-25-2006, 05:37 AM
Mine has about 22 psi at an idle, and at 1400 rpm, it's up to over 38psi.
Old 10-28-2006, 02:09 AM
Same here, I have heard from a cummins mechanic that higher oil pressures in a n14 will beat the cam bearings up pretty bad. Ours runs about 40 psi or so at 1500, 724k
Old 10-28-2006, 03:55 AM
The cooling nozzle should have shown a "sudden" change in the oil pressure; when they break, it creates a leak in the main oil gallery. If the cause was bearings, the change would come over time... almost unnoticably. Fuel will thin-out the oil (not too common in N14s), if it's a slow internal leak, the pressure will go down as the oil change interval comes to it's end. If the internal fuel leak is severe, the engine oil level will rise (overfull). The thin oil can cause a blow-by condition, which will cause blue smoke from the stack.
Doesn't hurt to at least "inspect" the rod and main bearings (bottom end) at 500,000 miles, especially if you didn't buy the engine new. The engine may have suffered head gasket or rocker gasket internal leaks (quite possible) which contaminates the oil and "wipes" the bearings. Watch the oil; conatminated oil will become sludgy (texture) or milky in appearance.
...Overhaul @ 1,000,000 , bottom end @ 1/2 way to overhaul.
The oil leak to "beware of" is behind the accessory drive pulley... if it leaks, it CAN cause major problems, have it checked right away!!!
Oh, and the 1st step in oil pressure diagnose is ALWAYS checking pressure with a "known good" manual gauge.
Old 10-30-2006, 04:50 AM
I still have low pressure in the N14. The repairs they made ( I posted earlier) helped some... for awhile... but I am now back to running about 25 p.s.i. at cruise speeds. When climbing a long hill on a warm day, if I don't gear down and RPM up sufficiently, I will get a Low Oil Pressure alarm on the dash.
Otherwise, she runs fine and does not use much oil (drips mostly). Previous owner replaced the bottom bearings but I wonder if they botched the job? :roll:
Theodore Roosevelt
Old 10-30-2006, 04:40 PM
One way to check for worn main and rod bearings:
When loaded, while driving steady on level ground , at say 1500 or so rpm, give the truck full throttle. Note the oil pressure under throttle.
Let off on the throttle completely and let the engine hold back. Stay the same rpm and speed as you were when at full throttle.
Watch the oil gauge. If the needle jumps more than a couple of pounds you have bad bearings.
This test had been right every time I have seen a 4 to 5 lb or more increase in oil pressure between pulling and holding back at the same rpm.
Old 11-02-2006, 03:04 AM
I will try that test!
Theodore Roosevelt
Old 01-07-2013, 06:31 AM
be careful with low pressure when climbing hills i had one that was that way and without warning one day it spun a main bearing 586000
