CFI/Conway truckload
This is a very good company, I worked at CFI for about a 1.5 before leaving for a car hauling postion. Not once did they do me wrong. Dispatch is FIFO( fisrt in first out). If you dispatch from a terminal you can pick your loads. I liked the trucks, brand new T600 with a 475 cat and a 13 speed. Truck was amazing, just about every load is light weight. (atleast the ones I hauled)
If you get a junk truck over there, you can thank your fellow drivers becuase the maintence program is great. All trucks go thru inspection every time you enter the terminal in Joplin. trailers are in good shape and the money is good as long as your willing to run. If you can't run legal let them know and they will adjust the time or relay the load.
Teams do get priority over there, but there is enough freight to go around. Only negative about them is laredo. Most of the time you will sit for a day or two waiting for a reload out. I would take this time to catch up on rest and watch a lil TV and do laundry.
When it was time to reload, I would ask for something going to the NE pays 1900 miles to driver plus four stops. It was always there, no driver wanted that run.
All in all great company, not sure if things have changed. But I had a great time there and met alot of good people.
