Idiling
Old 07-19-2008, 08:52 PM
Originally Posted by Mr C
At present fuel costs are the #1 problem that all companies and O/O's are really fighting. And yes for idiling the APU solution is probably the better direction to go. But many O/O can not afford & many companies are not installing.
Good point Mr C! Headborg to sum it all up below:
Originally Posted by headborg
Do away with the sleepers altogether-- saves money on cost of truck.There's no more sleeper birth split anymore- so having one is of NO advantage to a company.
Bingo! Headborg is right on the money again. That is the direction that the industry is heading. Sooner rather than later.......................
Interesting how some of these cut-rate outfits have suddenly discovered the necessary capital to outfit entire fleets with APUs :?: Hmmmm..............
Old 07-20-2008, 12:15 AM
Malaki86's Avatar
We had a couple drivers quit this past week over the idling time issue. I walked into dispatch just as the argument was getting heated between 2 drivers and one of our owners.
Basically the owner said that both of their idle time was too high (one was 52%, the other 54.5%) and they needed to shut down their trucks more. Both drivers had just come out of El Paso. Long story short, we now have 2 empty trucks in the yard and have lost 2 drivers who've been with the company 10+ years each.
Myself - if it's not too hot, I shut down. However, if I'm supposed to be getting some sleep and it's hot, the truck is running.
Old 07-20-2008, 04:29 AM
Default Re: Idiling
Originally Posted by Double L
Originally Posted by ORPLINER
As a new driver-I was just wondering - is it just my company(GTI) that has its trucks set so they will shut down after 5 minutes of idiling? Or are all freigtliner columbias like that from the factory. You have to engage the cruise control to rev the rpms up above normal idle for it to keep running if you want to stay cool.
It's a Freightliner thing, there was a Freightliner Columbia fuel tanker that was idling and shut off after 5 minutes. I do know the WIA model Volvos (97-98 models I think had them) shut down after 5 minutes if you don't have it on high idle.
the idle shut down can be disabled through the computer IF the buyer wants it.
Old 07-20-2008, 04:34 AM
Originally Posted by Drew10
headborg wrote:
The math just isn't going to work out for the driver- 24 hours in a day-- you can only drive 11 in a 14hour period-- that's only 45.8%-- the other none rolling time = 54.2% of which that 10hour break if idled continously will result in a 41.6% idle time.
Nope its not going to work out for the driver. Even with ideal dispatches and assuming continuous idle during your 10hr break, and assuming you drive 11hrs...thats just under 50%. More often than not an average day will not be 11hrs...but the 10hr break still exists. This will increase the % even greater.
APU's if your company doesn't have them on or planning on installing them-- they are either PLANNING ON going under-- or planning to stick it to the drivers.
I agree with you here headborg. If they cannot afford to put the APUs on and wait for the return in investment, then that company is hanging by a thread.
my boss doesnt plan on getting apu's Or making a no-idling policy OR going under, he simply asks us to use common sense. he will pay for a motel if you get stuck out because it's usually cheaper than idling, bt he knows if you sleep in the truck, it' gonna be running, what he does is makes sure he gets a good enough freight rate to cover it..
Old 07-20-2008, 04:39 AM
Jumbo's Avatar
Default Re: Idiling
It isn't just a Freightliner thing. Idle timers can be turned on or off or adjusted at a dealership or in the shop. I had Petes and Macks as well as the Freightliner I drive now, and they all had an idle timers on them. I think you can adjust the length of time before shutdown in five minute increments.
Old 07-20-2008, 05:27 AM
Malaki86's Avatar
I don't mind the auto shutdown timers, just as long as the driver can override them when necessary.
I've had the autoshutdown on KW's, International's, Volvo's and Freightliners. It takes all of about 5 minutes for the shop to disable/change the setting in the trucks computer.
Old 07-20-2008, 05:37 AM
there's another -- be it more radical solution--
it involves the drivers & companies-- getting 'on the same page' together.
Tie the safety/risk management director to a chair and stick his butt in a closet--- go back to a 'comic book' is just a 'comic book'---- run 'outlaw' operations--- and keep those wheels turning---- this is another big problem the industry is facing. The satellite & the safety department/log department has all the drivers scared senseless--- most drivers want to shut down and take their legal/required 10hr break at night--- they are have been gradually -because of parking shortage--- arriving at the T/S earlier and earlier trying to secure parking before sunset.----- Then, instead of getting up earlier---and starting their next 14 hour shif at 2 am etct--- those 10 hr breaks are being stretched longer and longer.
Given the current price of fuel--- companies need to keep the wheels rolling--- even O/O are finding that it's better business to take a lower paying freight rate that will break even-- relocate to better paying freight area-- than setting idle waiting for a better paying load.
Old 07-20-2008, 05:53 AM
Exactly HB. Which ties in perfectly to your earlier insightful post about getting rid of sleepers. Feeder networks, while not a cure-all, are a viable and effective alternative to the above described. The entire situation/crisis is quickly snowballing into a complete industry overhaul. Short to medium haul feeder systems. Long haul on an as-needed basis as a specialty probably to return to the independents/OOs.
It is certainly a rough shake-up. Yet one that I predict will benefit all of us drivers.
Old 07-20-2008, 06:16 AM
Colin's Avatar
Don't O/Os talk about how good a rise in fuel costs is for the bottom line due to a higher fuel surcharge?
Do companies not get this fuel surcharge?
http://www.trukz.com
Old 07-20-2008, 06:49 AM
The satellite & the safety department/log department has all the drivers scared senseless--- most drivers want to shut down and take their legal/required 10hr break at night--- they are have been gradually -because of parking shortage--- arriving at the T/S earlier and earlier trying to secure parking before sunset.----- Then, instead of getting up earlier---and starting their next 14 hour shift at 2 am etc--- those 10 hr breaks are being stretched longer and longer.
Bingo .....
We (as drivers) are left with no choice....
They make the slightest change in policy and it fans out like a ripple
in the water...... some of my 10's are now 14's and more :lol:
