Steer tires as all-position?
Old 04-30-2010, 03:26 AM
tracer's Avatar
OK, here's the secret list
"Verified Low Rolling Resistance Tires
Based upon data provided by tire manufacturers and EPA testing and research, EPA determined that certain tire models can provide a reduction in NOx emissions and an estimated fuel savings of 3% or greater, relative to the "best selling" new tires for line haul trucks, when used on all five axles on long haul class 8 trucks.* The options offered include both dual tires and single wide tires (single wide tires replace the double tire on each end of a drive or trailer axle, in effect turning an "18" wheeler into a "10" wheeler).* Low rolling resistance tires can be used with lower-weight aluminum wheels to further improve fuel savings.
To date, EPA has verified the following low rolling resistance tires. *In order to be eligible for funding under the DERA, verified low rolling resistance tires must be specifically listed on EPA’s verified technology list.
The following low rolling resistance tires are SmartWay verified when used on class 8, line-haul trucks:
Bridgestone
Steer* * R287A, R280, R250F, R260F,
Drive*** M720, Greatec
Trailer * R195, Greatec
Trailer, Greatec R125, R197, S197
BF Goodrich
Steer*** ST244
Drive*** DR 444
Trailer* TR144
Continental
Steer*** HSL-2 (replaces HSL), HSR1 ECO plus, HSR2 ECO plus
Drive*** HDL Eco Plus, HDL2 DL Eco Plus, HSR1 ECO plus, HSR2 ECO plus
Trailer** HTL ECO PLUS, HTL1
Double Coin*
Steer**
Drive*
Trailer**FT105
Dunlop Tire*
Steer***SP384 FM
Drive***SP456 FM
Trailer**SP193 FM
Firestone
Steer***FS590 PLUS, FS507
Drive*** FD662
Trailer* FT455 PLUS
Goodyear
Steer*** G395 LHS Fuel Max, G399 Fuel Max, G662 Fuel Max
Drive*** G305 LHD Fuel Max, G392 SSD, G305 Fuel Max AT
Trailer** G316 LHT Fuel Max, G316 Fuel Max DuraSeal
Michelin
Steer** XZA3, XZA2, XZA1+, XZE, XZE2, XZA2 Energy,
Drive*** XDA2+ Energy, XDA Energy, XDA3, X-One XDA, X-One XDN2, XOne XDA Energy, XDE2+, XDN2, XDE M/S
Trailer** XTA Energy, XT1, X-One XTA, X-ONE XTE, XTE
Toyo Tires*
Steer*** M137, M154
Drive**** M657
Trailer** M127
Yokohama
Steer*** RY617, 103ZR, 101ZL
Drive**** 703ZL, TY517mc2
Trailer** RY587mc2, RY587
Hankook
Steer*** AL07+, AL11
Drive*** Z35a, DL11
Trailer** TL01"
Anyone had experience with these and did you notice any fuel savings?
Watch my YouTube videos
Old 04-30-2010, 04:39 AM
tracer that list is somewhat misleading, because there are tires out there that have lower rolling resistance yet aren't on that list. Michelins site has a rolling resistance calculator.
Old 04-30-2010, 10:32 AM
tracer's Avatar
i tried their calculator but couldn't figure out the abbreviations for the truck and trailer configuration... is there a simpler version of this somewhere, the "for dummies" type?
tandem axle truck - 6x4 or 4x2?
tandem dropdeck trailer - ?
Old 04-30-2010, 11:41 AM
6x4 and just any tandem trailer, doesn't matter that it's a step deck
Old 04-30-2010, 03:17 PM
heavyhaulerss's Avatar
Originally Posted by tracer
Are you saying you had STEER tires on the drives? What make and model?
they were steelmark. paid 2 grand for the whole 9 yards. no trade in. none developed any dips, got 6.8 m.p.g. on a mil mile truck. I did have to have a few flats fixed thruought their lifespan. they are not as deep in rubber, so some things will puncture all the way thru if you run over nails, e.t.c. on the deep lugs, many times , I would pull a nail or small bolt out & still be o.k.
the steelmark is a inexpensive chinese tire. I may try a better brand, just to see if the ride is smoother. long ago I had kelly steers & thought the ride was normal. felt like they bounced my eyeballs outta me head. went to b.f. steers & it was such a huge difference, I would not of beleived it unless I experienced it my self. the b.f.'s rode like a dream compared to the kelly's.
Old 05-10-2010, 05:41 PM
YerDaddy's Avatar
I have 10 BFG ST244s on my tractor and love them. Great ride, mileage and quiet too. Wearing perfectly.
Lugs don't make as much difference on a class 8 truck as they do on a four wheeler. Truck suspensions are too stiff for the tires to have as much effect as you might want to think, especially when you have all the weight/momentum added to the situation.
Old 05-10-2010, 11:26 PM
I think the bfg st244 is what I have on my steers. I thought about going with them on my drives, or a regular hyw tire. someone told me that a kelly kda weighs 20- 30 lbs more than a hwy tread & has a lot more rolling resisstance. the main thing I liked about the hwy tires I had was the ride. if a lug starts to dip, you either put up with it or change it. just like anything else... personal preference.
Old 05-11-2010, 01:38 PM
to the people that are running steers all the way around.. are you noticing the truck is floating more? i'm wondering because i run a single axle if it has anything to do with it.
Old 05-11-2010, 02:14 PM
tracer's Avatar
What part of US/Canada do you ride in? Does the truck handle okay in winter with these tires? What size tire is your BFGoodrich? I checked the specs and they do spin faster per mile than my current Yokohama TY517 (512 revs/mile). Thanks!
Old 05-12-2010, 09:13 AM
I have 22.5 at the time I had the steelmarks I was in MI thru a bad winter storm & had no problem. I know my kellys cannot spin as much per mile as the hwy tires cause they are min 2" taller that is being the same size, 22.5 standard. side by side the kelly are quite a bit taller. with the kellys, they are so deep that for the first 30,000 miles it feels like your driving on wet noodles.
