Best APU
Old 09-17-2008, 06:14 AM
Originally Posted by NotSteve
Dickhead.
Where'd that come from?
Weigh Station Info that Matters
Old 09-17-2008, 07:02 AM
If you get a Rigmaster, you have to be cool and get a rooftop A/C (and wear a kick me sign on your back on CAD for a few months) :lol:
That was in response to BanditJerk. I kicked his azz a month ago and he's still pissed about it. Or at least I think I did. My memory isn't so good these days.
Old 12-21-2008, 05:44 PM
Is that Onan a Cummins comfortgaurd? I,m looking at apu,s and thinking of thermo king tri pac or Cummins comfortgaurd. heard lot's of good things about tri pac but nothing about the comfortgaurd. I like the options on the comfortgaurd but would like to hear some comments on them. Anyone out there got one?
Old 12-23-2008, 03:03 PM
Musicman's Avatar
We had a TriPac for about eight months (until our truck was stolen), and it was decent. I did not like the “Arctic” feature on it that is designed to heat the entire truck engine by circulating the coolant, because that little diesel engine would never generate enough heat to make any real difference in the temperature of the truck’s coolant. Also, the TriPac does not put out enough cooling BTUs to cool a high rise roofed truck in extremely hot weather. When sitting in Ontario, CA in the summer, for example, we would have to start up the truck and idle 5 minutes out of every 30 to keep it reasonably cool. Also, the TriPac and most other APUs don’t put out nearly enough electrical energy… if I remember correctly most APUs including the TriPac only come with a 65 amp alternator. Despite its shortcomings, the one thing that was great about our old TriPac was that it could be serviced at any TK dealer.
We now have a Comfort Master APU, which is great in a lot of ways. It has two alternators that put out a combined 400 amps of power. It also cools well enough to freeze you out of the truck, even in Phoenix in July. Same thing goes with the heat in Fargo in January. It also comes with a 3000 watt inverter that you can plug into shore power to keep your batteries charged, etc. . The problem with Comfort Master has always been that the units are a bit quirky. The designer of the system tried to make it do too much too quickly and the result was a few irritating problems with the system that will cause it to occasionally error code out and turn off. Now it seems that the credit crunch got the best of the company and it is currently out of business. Luckily all of the parts in the system are easy to find from independent dealers, and the Isuzu engine warranty can still be serviced by outside dealers if problems arise there.
My advice is to put a lot of thought into what you want from an APU. Some systems are better than others in particular areas. Define the things that are most important to you, do a little research and buy the APU that most fits your wants and needs. Also keep in mind that in California, and soon many other states as well, you will not be able to use an APU on a newer (’04 / ’07) truck unless the APU meets the same emission standards as the truck. I have noticed that some of the APU manufacturers are now offering upgrades like particulate filters that should make their APU CARB compliant, but if you run in these emission control happy states, make sure that what you are buying will be legal there.
Old 12-26-2008, 06:50 AM
BanditsCousin's Avatar
My truck stays very cool in Vegas in 100+ degree weather. I have a newer unit, a white truck, and a 86" studio sleeper. It might be that the unit was newer, but I doubt it. I have no complaints, but it won't cool you all too well up front in the seats.
I've heard a few complaints about the Tripac's cooling ability, so i could be an exception, or easily pleased. I also noticed the Arctic package only makes the APU run more, and I'm still finding out how it warms the coolant (being my first winter). Overall, I'm happy with the Tripac.
Mud, sweat, and gears
Old 12-26-2008, 07:12 AM
I think it just uses the trucks coolant system for cooling.
Old 12-26-2008, 10:16 AM
The tripac uses its own system with a condenser and aux. fan mounted on the back of the sleeper. It does use some of the truck's ventilation system as routing. Mine came with 1 custom hose/vent installed under the sleeper and lumbed into the rest of my vents in the sleeper.
Old 12-26-2008, 12:18 PM
The first you described is the air conditioning system, not the cooling system.
The second is the espar heater under your bunk.
There will be two coolant lines going to the tripac probably. The reason you cannot run the tripac while the truck is running is the tripac uses the trucks coolant. Both cannot be on at the same time.
Old 12-26-2008, 12:59 PM
Musicman's Avatar
You are correct about the two coolant lines. They patch them in from the heater lines running to the bunk and connect them with “T’s” and ball valves. They claimed you could run the APU with those valves closed, but a few mechanics told me they wouldn’t personally do it.
You are incorrect about not being able to run your truck and the TriPac simultaneously. My alternator went kaput and we drove for about 12 hours using the TriPac's tiny alternator to keep the batteries charged. You run into problems idling the truck and running the TriPac for any length of time, or at least we did, because the coolant will heat up too much. The conflict is that the truck likes to keep the coolant at a minimum of 175 degrees and the TriPac turns on its radiator fan when the coolant reaches 130 degrees or so. We did do it, as I mentioned in an above post, for five minutes at a time to keep the truck cool when parked in the sun and ambient temps above 100 degrees Fahrenheit and had no problem.
Old 12-26-2008, 01:07 PM
Thanks, didn't know that. A few people have asked if you can run both at the same time, how do you actually do it?
