Using ether to start a cold engine
Originally Posted by JBenson2
Sealord said:
I idle, particularly when I'm sleeping and want to keep warm
As I understand it, idling laws don't apply if you are IN THE SLEEPER, though I think some places back east set temp restrictions (eg. it must be above **degrees to use the AC or below ** degrees to run the heater). By the way, HELLO to everyone. I began trucking in '76 to '86, took a forced break & started again from '97 til now. A lot has changed, and not for the better (except the equipment is much better).
What happens when your in a state that has the idle law. Lets say it's 90 outside and you get a ticket. Is it just one ticket for the duration that your parked or do they bang on your cab until you stop. I guess my real question is, does a $25 dollar ticket or whatever buy you the luxury of A/C for the night?
[quote="yoopr"]
Originally Posted by Midnight Flyer
While talking to an old salt driver today he told me that it was once required to use a shot of ether to start the diesel engines of old on frigid mornings. With today's modern technology is that still required? 8)speaking of plugging in.... i have a plug(block heater?) near my drivers side door....i park truck at home daily...is it true all i do is plug into wall and to block heater and that will prevent a cold start in the a.m.??????
[quote="marcel27208"]
While talking to an old salt driver today he told me that it was once required to use a shot of ether to start the diesel engines of old on frigid mornings. With today's modern technology is that still required? 8)speaking of plugging in.... i have a plug(block heater?) near my drivers side door....i park truck at home daily...is it true all i do is plug into wall and to block heater and that will prevent a cold start in the a.m.?????? One more note on ETHER... I once ran a piece of equipment that had an "AIR PRE-HEATER". It was an electric element in the intake manifold that would glow red and heat the air before it went into the cylinders. Spraying Ether, no matter how much or how little, would cause a VERY SERIOUS EXPLOSION in the intake. If your engine is equipped with this, DO NOT USE ETHER!!!!!
YES ! ! ! There is life after trucking. a GOOD life
When ya'll say "idle", do you mean leaving the engine running while you sleep? If so, that probably burns a s***load of fuel. I've seen drivers do that at truck stops before in the middle of the night. They'd have the curtains drawn over the windshield and windows. It'd be on a summer night too, which means they'd have the A/C on,... buring more gas!! :shock:
This was 20 some odd years ago that I was told this,so,it may be different now days. I was told once that diesel uses about 5 gallons every 12 hours,when idling
Could be anywhere between 0.5 to 1.5 gallons an hour. According to ECM, my average idle consumption, is 0.71gph. :roll: When i did reply to Steve, i mean cost of that ticket, not fuel!
You can take the driver out of the truck but you cant take the truck out of the driver. |
