High Expectations??? Please Help!!!
Originally Posted by Rawlco
Originally Posted by Highwayman
Originally Posted by Eastboundanddown
Now for the 3 weeks out I?m assuming you would take a couple of days off during that time.
I keep seeing ads of $50,000 gross a year per person. Is this a realistic expectation with us working as a team or would we have to break laws and work very long hours? Or is $50,000 realistic after the first year?
And how is a solo driver different? You are paid to move freight, not sit around. There's much more to life than wasting it sitting in a truck all the time.
Originally Posted by syl77dar
don't do xpress cuz after 1st of year you will get no runs at all. furthermore, there trucks break down a lot and trailers are worse yet. then they give best runs 2 senior drivers and teams.
Ive driven for them for 1 year. They started me out in a 04' peterbilt(beautiful). It has 355k miles on it, and next week they are giving me a 07' petebilt.
And the logic isn't right- after the 1st year you will get no runs and yet their 2 senior drivers and teams get the best runs... how can that be right. Apparently the "two" senior drivers and teams are getting runs- I imagine that they are reliable. I also imagine there are other reliable teams/drivers that are getting good runs too- it's just you hear the unreliable drivers/teams whining a lot louder.
_________________ It's always the company's fault.
pain and heartaches aren't options in this life... misery is a choice.
picking the right co. will be key here. you are a professional and will ask lots of tough questions and present 'what if' scenarios. document everything by communicating with email. choose a co. with lots of drop and hook freight to eliminate THE biggest time looser there is in this business- Waiting for loads should be minimal!! Just enough time for you to get showers and eat. Choose a co. that wont make you sign a contract, with a good rep and good pay. 40cpm split?? you should be able to do a bit better, however I dont have much to compare to off hand. You should be able to run 1kmiles in a 24hr period or at least 8oo miles if you use the 8 hrs each method as per the new (bs) regulations.
5k miles a wk. is low, you can do that in 5 days once you are used to sleeping with a moving truck and when each driver can run the truck as if they were alone. Staying out weeks at a time makes you a big asset to the co. as you can go anywhere, anytime and can choose to take a few days off while close to home provided that you let them know before they schedule you for another load. Be sure to get looooong runs to do over the weekend, they will be the easiest running, best paying through less delays and traffic, no scales open, long run means less stopping and bypassing cities. You can do well!! Check into Conway truckload, they run only teams, and have good equipment (volvo 770). I used to drive for Conway Now that does expedited runs and they were very professional to say the least. Trckload was run from the same office. Avoid expeditors though, you will sit too much waiting on loads. GOOD LUCK
Eastboundanddown?? :shock: I seem to recall a guy who called himself "WestboundandDown"!! :shock:
Sure hope we are not dealing with Multiple Personality Disorders here!! On the other hand, if you do have Multiple Personality Disorder, then you would be covered under "The Americans With No Abilities Act", so you could run multiple log books, and no one could mess with you!! I will say this much; if you live in Florida, but insist upon being "EastboundandDown", then you are going to have a very difficult time getting any miles!!
The thing I question in this is the 55 mph to calculate the number of hours it takes for a driver(in this case team drivers) to get their miles. Nobody averages 55 mph when dealing with stops, and all the other misc stuff that has to be done and impedes getting ones miles. I I would guess that the driver will be looking at a 10-12 hr day, and then switch(just my guess). YMMV
The other thing that should be noted is the team pay at USX is per diem pay. This can be a negative depending on your tax bracket, how close you are to retirement, and social security situation. BOL Longsnowsm
Politicians are a lot like diapers, They should be changed frequently, And for the same reasons. |
