Old 11-02-2013, 03:36 PM
carlt75's Avatar
Default starter problems
How fix a dragging starter
Old 11-02-2013, 04:08 PM
chris1's Avatar
Replace.
Old 11-03-2013, 11:22 PM
Make sure that your batteries are fully charged and all connections are clean and tight. If everything looks good, then you need to replace your starter as chris1 suggested.
Old 12-31-2013, 02:35 AM
heavyhaulerss's Avatar
a dragging starter will drag down your batteries, then the next post will be how to fix dragging batteries.
Old 12-31-2013, 03:50 PM
I had to rebuild one of my starters this summer. It was much cheaper than buying a new starter. Replacing it while home will be much cheaper than being forced to do it out of town.
Old 01-01-2014, 04:49 PM
I had a starter rebuilt by a local top notch shop that only does alt, starters, e.t.c. for $55.00. put it in my side pocket.
Old 03-26-2014, 08:48 AM
janeclark's Avatar
Making sure that your battery is fully charge is very important and that fact that you need to have a complete tool to fix it ,but for me it is better if you go this problem to expert cause some if you don't know that problem it will cause another problem ,just like an bearing or laakeri that i used to replace where i thought its fine but when i use it there is another problem.
Old 04-10-2014, 04:55 PM
NancyLong's Avatar
Yeah I also suggest that to make sure your battery is fully charged. Apart from that you should check for wire missing in the starter system.If you have tried both then consult some technical export to fix this problem.
Tags
rr3-y39
