starter problems
How fix a dragging starter
Replace.
Make sure that your batteries are fully charged and all connections are clean and tight. If everything looks good, then you need to replace your starter as chris1 suggested.
a dragging starter will drag down your batteries, then the next post will be how to fix dragging batteries.
I had to rebuild one of my starters this summer. It was much cheaper than buying a new starter. Replacing it while home will be much cheaper than being forced to do it out of town.
Making sure that your battery is fully charge is very important and that fact that you need to have a complete tool to fix it ,but for me it is better if you go this problem to expert cause some if you don't know that problem it will cause another problem ,just like an bearing or laakeri that i used to replace where i thought its fine but when i use it there is another problem.
Yeah I also suggest that to make sure your battery is fully charged. Apart from that you should check for wire missing in the starter system.If you have tried both then consult some technical export to fix this problem.
