Steering wheel wobble at 50 mph
Old 09-03-2011, 03:46 PM
Alignment could be your answer since they look at all components.
Old 09-05-2011, 12:10 PM
I'm getting one done tomorrow for a different reason.
Old 09-06-2011, 03:47 PM
Yup back axles were both out. #1 was 3/32" and #2 was -1/8". He bent the front axle as well, camber on drivers side went from 5/8 a degree to 3/8 a degree. pass side is -1/8 a degree.
Toe is untouched(I check it regularly). Caster is 2 3/8 degrees left and 3 1/2 degrees right. I think both could be a little higher.
Old 09-09-2011, 12:15 PM
Could be worse, had a vibration in 18th and ended up replacing the trans, ouch.
Old 09-09-2011, 10:26 PM
Company we get our tires from, they put in what they call balancing balls on larger tires. Never had any issue with a tire vibration with those. The truck I drive doesn't have any wheel weights or balls inside, no vibration but the steer tires have some funny wear on them. By the looks of it, you'd swear I have a serious vibration or wobble in the steering wheel but I don't. Funny how tires work sometimes.
Old 10-22-2011, 09:30 AM
Originally Posted by allan5oh
I have a strange wobble right at 50 mph. A couple mph above and below it is no longer there. When the steering wheel wobbles it also feels very loose. I found the weights on the passenger steer tire were gone, so I had both rebalanced. They are not out of round. The balancing seemed to help, but I still notice maybe 20% of the time at 50 mph the wobble is back. There doesn't appear to be any other issues in the suspension/steering. I went over everything, and replaced the drag link and shocks. Wobble is still there.
Is it more noticeable when accelerating? big or small rubber?
