do anyone
Old 09-01-2010, 12:51 AM
xcarsalesman's Avatar
Default do anyone
Does anyone know a good and respectable shop. i have a cracked manifold. What are the going rates to have one replaced. i do have a warranty , buts its not covered under it.
Old 09-01-2010, 01:06 AM
What area of the country do you want to find a mechanic? I have seen rates from about $50-115/hour, lately. I would probably try to find a smaller shop rather than a dealer. I know a guy in Arkansas who is reasonable. I know another in Georgia who is fair and does a good job. There is also a shop in California that I have used who does a good job at a fair rate. If you don't find the response you want you could do a search on NTTS and probably find a garage almost anywhere in the country.
Old 09-01-2010, 02:07 AM
Based on his other post I think he's in South East. Henboy knows guy in Atlanta Area. If you belong to OOIDA they have a list of shops
Old 09-02-2010, 12:46 AM
thanks for the info, yes i am a member of ooida, i will check them out
Old 09-02-2010, 02:41 AM
Someone I know of just had one done and it was 4 hours labor plus parts. It came to about $1200.
Old 09-03-2010, 06:12 AM
Maniac's Avatar
Just a FYI, Cat in central Jersey is now $137.50 an hour for labor
Cleveland bros Cat in central Pa is $90.00, big difference for 200 miles away
Old 09-03-2010, 06:21 PM
YerDaddy's Avatar
Intake or exhaust manifold? What makes exhaust manifolds such a PITA is the studs break when you try to remove the bolts. Then you gotta weld them bee-otches out. I had 5 out of 10 break when I had a gasket leak to fix. Those high tensile strength missile rods are amazing!
Old 09-04-2010, 12:48 AM
:eek2:
My local shop is $55 an hour. Why anyone would pay those insane rates is beyond me.
Old 09-04-2010, 01:44 AM
Originally Posted by Rev.
:eek2:
Is that an independent shop or Peterbilt?
