Old 05-16-2010, 02:48 PM
Originally Posted by Roadhog View Post
I'm just sayin'
It depends on the extent of the damage. But I hear you...most shops won't take on the liability.
Some shops do specialize in aluminum wheel repair and restoration.
From what GMAN describes, this is a slight bend in the bead. You don't want to see a crack, but this doesn't sound that messed up.
This is my sisters shop > Extrusion Tool Manufacturer and Design : MasterCraft Extrusion Tools
I've worked there off and on. Just when I thought I was out... they pull me back in.
[youtube] <object width="500" height="405"><param name="movie" value="http://www.youtube.com/v/UPw-3e_pzqU&hl=en_US&fs=1&rel=0&color1=0x5d1719&color2 =0xcd311b&border=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/UPw-3e_pzqU&hl=en_US&fs=1&rel=0&color1=0x5d1719&color2 =0xcd311b&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="500" height="405"></embed></object> [/youtube]
Bragging rights...
They built the worlds largest seamless die.
It was for the Space Shuttle. See the photo > Extrusion Tools & Extrusion Dies : MasterCraft Extrusion Tools
You can't tell that it is bent by looking at it. The only way the garage could tell was when they rolled it. The rim went to one side. It isn't cracked. Thanks for the references. By the way, I live in Chattanooga.
Old 05-16-2010, 03:28 PM
From the repair methods I've checked out, most would use a hydrolic press to straighten the wheel, and a dial indicator to check for true.
These shops have a machine set up for that job.
At our machine shop, I'd be able to set up to use our press to straighten, then I'd have to mount to a lathe to check with the dial indicator. Probably have to go back and forth several times, before I got it straight. But still, I'm sure I'd do it for myself or a friend.
(I love fooling around in that machine shop on weekends with my own little projects)
I have a project sitting out back half finished right now. A nice heavy duty single axle work trailer, with electric brakes.
(I built 3 double axle trailers w/elec. brakes in the past and sold them... this one is for me.)
Before that I made some sweet hunting knives out of D2.
I still want to design a better mouse trap. Like a mini-claymore trip, or a guillotine.
But right now, I spend most of my time picking splinters outta my butt from sitting around pining for Elizabeth Hurley.
Old 05-16-2010, 06:52 PM
If we lived closer I would consider having you to try to repair it. :thumbsup:
Old 05-16-2010, 08:37 PM
Kranky's Avatar
Anything can be fixed if you want to throw enough money and time at it.
That said, unless you can get the machine shop to work for free, why spend money fixing something that can probably be replaced with a new one for not much more money?
With a new wheel, you know it's true, and you know it's not metal fatigued from being bent and then pressed straight again.
If it was mine, I'd put a new rim on it and be done with it.
Besides, the price of aluminum scrap is up right now.
Old 05-17-2010, 02:25 AM
The last aluminum wheel that I bought cost about $400. I was told that the scrap value is about $18.
Old 05-19-2010, 12:19 AM
Maniac's Avatar
A repaired aluminum wheel usually won't run true anymore, will eat the tires............scrap it, A new polished wheel is under $300, unpolished is even cheaper
http://4statetrucks.com/index.aspx?s...XP=Y&iABSP=M_1
Old 05-19-2010, 04:39 PM
I didn't know you could repair an aluminum wheel. I thought they were junk, once they got bent, cracked, dented etc.
GMAN, it's pretty said, isn't it? You buy a wheel for $350, and then you have to scrap it, and only get $15 for it. :hellno: :rofl:
Old 05-23-2010, 12:57 PM
Yep. It is a shame that you can only get about $15 for a used aluminum rim. I had a driver who bent one a couple of years ago and I believe that it cost me $400 to replace it.
By the way, the only way that you can tell the rim is bent is by rolling it. When you look at it you can't tell that it is bent. That is one reason that I would like to salvage it, if possible. That and the $350-400 for a new aluminum rim.
Old 05-23-2010, 01:46 PM
Bigmon's Avatar
I got $37 for mine. 24.5". Depends on the price of aluminum.
Old 05-23-2010, 03:52 PM
repete's Avatar
I used to sell auto parts and the Co had a nation wide distribution system for "remanufactured wheels" now I no these were car / pick up wheels but the process would be the same. One of the "rules" were it couldn't be bent or cracked in the hub area. So if the damage is on the flats by the lug nuts... sorry buy a new one. We had some specialty wheels repaired that had some large chunks out of the bead area and when they come back you had to look real close to see the welded area. Check out having it repaired but I'm sure it's gonna cost at least $200 that's getting close!
