Engine jumps 100 rpms for a couple seconds
Old 03-05-2010, 05:37 PM
Default Engine jumps 100 rpms for a couple seconds
I just recently had the clutch done, and now occasionally going up hills it will gain 100 rpms for about 1-2 seconds then come back down to normal. I do have the "low to high" grinding problem occasionally (maybe once a month?) and I was going to do that but didn't have the time. Maybe I should've. Could that be it?
I always thought it would "jump" if it was the range. Not just feel like something is slipping.
I did have an air leak problem, the blue line rubbed through but I fixed that(happened shortly after the clutch job).
Old 03-05-2010, 11:20 PM
I had to put a clutch in last year and the first couple hundred miles the truck did the same thing.My mechanic called the manufacture of the clutch and said sliping was normal for breaking in.After that it never did it again.maybe thats whats happening to your truck.
Old 03-06-2010, 12:57 AM
Kranky's Avatar
If the range shift was jumping out on a hard pull you'd know it! There would be one hell of a bang and tremendous shock unloading/loading of the entire driveline, probably with secondary damage to other parts from the shock.
So, that suggests clutch slippage.
Better pull the bottom cover off the bellhousing and check for proper clearance between the release fork and throwout bearing when the clutch pedal is all the way up. If not correct, adjust the pressure plate until it is.
No sense burning up a brand new clutch.
Old 03-06-2010, 01:38 AM
Thanks guys, I'll check it out today. There is nowhere near a bang, if I was distracted I'd probably totally miss it. It feels like wheel slippage, but normally when I have wheel slippage there's no increase in rpms or speed on a hill, but the cruise actually throttles back. This was totally different, no throttle back, no change in speed (actual or gauge) but just a small increase in engine rpm.
Old 03-06-2010, 06:53 AM
Clutch replacement questions; Was flywheel re-surfaced? Is clutch adjustment correct? Was the clutch burnished after installation?
Who was clutch manufacturer (or rebuilder)? ...I just can't imagine why a clutch manufacturer would tell anyone that break-in slippage is normal? Oooops, wait a minute; their warranty doesn't cover blue clutches, that would fall into the category of driver abuse.
Old 03-06-2010, 02:22 PM
Well it turns out the slave cylinder wasn't adjusted correctly, it was putting pressure on the throwout bearing. On Volvo's the fingers that push the throwout bearing like to wear out, and you need to slowly lengthen the rod that touches the slave cylinder so that the clutch brake will work. I guess when you rebuild everything you need to shorten that rod as short as it will go. As we were shortening it the 1/2" clutch adjustment started to open up more. So then we went all the way, and adjusted the clutch back. We believe the adjustment is correct now, but now I'm worried that they put the slave cylinder rod assembly on the wrong tooth, and no amount of adjustment will compensate for that. I believe that is called being out of time, or being out of phase.
Unfortunately I don't know of any way of checking if the fingers are putting pressure on the t/o bearing. Does anyone know how?
Bob to answer your questions the clutch is a rebuild, the flywheel was machined (they said it was quite worn), and I do not know about clutch burnishing, please explain so I have a more informed conversation monday morning with the installer and Volvo.
The slave cylinder was replaced on installation, as well as the cross shaft/bushings, input shaft, tranny mounts, etc..
Old 03-06-2010, 03:49 PM
Heh, if they think it falls under that, they'll have a serious fight on their hands! I'm probably the easiest driver in the world on clutches. I don't sit at a light wearing out the t/o bearing by having the clutch to the floor, and every time I start it's in low gear even with an empty trailer. Only bobtail do I start in 1st.
Old 03-06-2010, 06:03 PM
Did some reading on hydraulic systems, and they do not have free play which is what I thought. However I think what was happening is the slave cylinder was pulled fully back(clutch pedal not touched) yet there was still a lot of tension on the throwout bearing. I'm going to look at it tomorrow, to see how much tension is on the rod attached to the slave cylinder. I'm assuming there should be absolutely no tension. The rod pushes back on the hydraulic system, but since the pedal is fully up the system is not closed and the rod just pushes fluid back up into the resevoir.
Am I on the right track bob?
Old 03-07-2010, 12:37 AM
Kranky's Avatar
With the usual pull type clutch setups there should be 1/8" clearance between the fork and throwout bearing, however I'm not familiar with the Volvo hyd clutch setup.
In any case even if the fork is supposed to have zero clearance with that setup, you do not want the fork exerting any pressure on the throwout bearing when the pedal is all the way up, or partial disengagement and slippage will result.
Old 03-07-2010, 02:14 PM
Looked at it today and I'm very happy with it. I can move the outside of the cross shafts with my thumb, there's a little clutch adjustment indicator. The clevis rod goes into the slave cylinder about 3/8". I just have to adjust it well before the fingers move that far. Otherwise it will bottom out again and put pressure on the throwout bearing.
One thing though the little tab indicator was right in between the "clutch needs adjustment" and "normal operation" areas, right on the line. Is that ok? There's a large range of "normal operation" and a small "clutch needs adjustment" area. Do you look at it when the clutch pedal is up or depressed?
I also noticed last trip my fuel mileage increased, probably because the throwout bearing was seized before. That sucker must've been getting really hot with all that friction. You couldn't move it by hand.
