Fan clutch.
Old 01-25-2010, 09:00 PM
heavyhaulerss's Avatar
Originally Posted by allan5oh
You probably have multiple problems, and you might have solved a few of them already. The fan clutch will only get air while the engine is running, so it is not a "loss of air while parked" problem.
You've covered a lot of fittings, but have you really hit every single one? What about the fittings in the dash, on ABS relay valves, on top of the transmission, on the firewall, etc..
After that absolutely cover every single air bag. I once had a hole right in the middle of one. Couldn't hear it. You also have to check exhaust ports on all the valves, as well as the arms coming out of leveling valves. Another possibility is the quick drain cocks on your air tanks. Sometimes they need to be snugged a little more.
As far as your air dryer pissing off every 10 seconds, that's a serious problem that should be addressed. Are you losing enough air pressure during these 10 seconds (say from 120 to 100) to cause your air compressor to turn on or are you barely losing any air? If you are losing that much air you need to get it fixed. That could put you in serious trouble, plus air dryers can only handle a compression event every 120 seconds or so.
If it's not an air leakage problem, it may be the governor, air dryer or the air compressor itself. There are valves in the air compressor that can bugger this up. Look closely for any leaks on the lines going to and from these 3 items.
IMO you should absolutely get rid of ALL quick disconnect fittings and replace them with compression fittings. That's what I'm doing. I've finally got my truck to compress every 20 minutes or so. It's been a battle. I've probably changed about 20-25 fittings so far, and I'm just going to change the rest(some of them cannot be changed to compression fittings due to their design, blasted Volvo!).
After all this is done (checking all fittings, valves, relays, drain cocks, sensors etc..) you have to look at air actuated systems that could possibly drain internally due to bad seals, like transmissions. I've heard of the range splitter actuator leaking right into the tranny.
I have replaced all air bag's. all fitting's are good. yes dash valve good too. replaced ALL, valve's like on top of rear going to brake line's, the 2 under the 5th wheel & the one in the front under the truck, plus all air lines going to tran's & shifter knob, e.t.c. the fan hub does leak when truck is off. I thought key had to be on also, for it to leak. truck off, it leaks. had 20 year mechanic/ o/o look at it. he said it was the fan clutch/hub. looking at the bendix air dryer trouble shoot websight. it told me where to look for my leak based on my symptoms. as far as the constant purging, it does not show lose on dash gage. it stays at 120 & does not drop unless i use brake's. then drop's normally & then right back up to 120.I also have no quick disconnect fitting's. all compression. I have taken dash apart, I crawled under truck from fron to back, checked all possible place's for leaks. when I soaped the fan hub, it really bubbled up. I ordered one yesterday the 25th. has to come from MN. should be here by thurs, will have put on fri, if all work's out well. I am a serious preventative maint person. I change belt's every year reguardless of look's. just like the air bag's, after so many miles or years, it get's replaced. I appreciate the info Allan. I have done all you recommended, & rechecked those parts that was replaced again, & again.
Old 01-26-2010, 04:37 PM
The small line going to your air compressor is losing its charge, that is causing the compressor to compress very quickly, but you have a quick decompression since the governor is hitting the psi limit(that you were at anyways). Make sense? The small line is the signal line, it's leaking somewhere.
BTW if your fan clutch is leaking while off, it may be the air actuator is internally leaking as well.
Old 01-26-2010, 04:54 PM
No! does not make sense. I am not smart enough to understand what you are saying. the small line is leaking? the 2 lines that are connected to the govenor are the same size. I understand I have a leak somewhere. your thought it is in the small line going to compressor? from where to compressor?
Old 01-27-2010, 03:02 AM
I'm sorry I've never been good at explanations. I'm not 100% sure where that small line goes to. But I do know that it controls when the compressor pumps. If there is pressure the compressor stops pumping, but with no pressure in the small line the compressor will pump. So what may be happening is this line loses pressure causing the compressor to pump. But since you're already at max pressure, the governor kicks off right away. Then in a few seconds the line loses pressure again, causing the compressor to pump again, etc..
It either goes to the governor or the air dryer. Either there's a leak in the line, fittings, or at either end(internally in the compressor for example).
What you could do is splice into this line and put a pressure gauge on it to see what happens.
I wish bob h was around he'd be a great help.
Old 01-27-2010, 03:22 AM
I beleive I can grasp that concept. thnak you.
Old 01-28-2010, 04:21 AM
Default great info on clutch, & dryer.
Great info here on the fan clutch, & the bendix ad-9 trouble shoot guide
http://www.bendixvrc.com/itemDisplay...ocumentID=2568
Remanufactured Fan Clutches and Rebuild Kits
the short video on the clutch is informative.
Old 01-29-2010, 08:40 AM
Fan clutch in. $495.00 for part, $175.00 labor to have put on. prices varied from $675.00 to 495.00 the one I got came from kit masters. thanks for all who gave advice.
Old 02-08-2010, 12:48 PM
Originally Posted by rank
I'm not understanding how a fan clutch that leaks air can cause the engine to over heat.
I help change a fan clutch on an M11. Or was it an N14? I can't remember. But it was a bugger. Not much room to work without taking the rad out. IIRC, we cut a section of the fan shroud out so we could remove the fan. With the fan out of the way, there is room to work. Then we pop riveted the piece of shroud back in place.
Me, I don't like air leaks. I figure every time that air dryer sneezes, my compressor dies a slow death.
Really?
Try removing the fan from the hub and set it inside of shroud (place cardboard or something between fan and rad to protect). Then, unbolt fan hub bracket and lift unit out using the fan drive belt. Rebuild hub on the bench, then reinstall.
Old 02-08-2010, 01:58 PM
Back when I had my own truck, I had to re-do the fan clutch twice. The seal kit to take care of the air leak is fine, but as long as you have it apart, I would replace the bearings as well. Hope that came with your kit. I didn't replace the bearings the first time, but decided that since I was getting into it the second time, I got the bearings too. Boy, was I glad I did. The inside one was on it's last legs.
Old 02-11-2010, 10:34 AM
I got the whole hub. not the kit. I will say this was a major air leak. before with both air tanks full 120 p.s.i. with truck off, in 3 hours tanks would be empty. now after truck off for 20 hours, air lose, 15-20 lbs max. this was an overlooked, overdo fix.
