Old 11-09-2009, 03:24 AM
merrick4's Avatar
Default Slipping out of 10 Gear
Have a truck that when it hit's top speed it slips out of 10th gear. Put it back in and 10 minutes later it slips out again.
Someone mentioned a spring to me; hoping I won't have to replace a transmission or anything.
Goin to get it into a shop tomorrow, but anyone have any ideas on this?
Thank you
Old 11-09-2009, 12:56 PM
Sabine's Avatar
I've driven two trucks that had that problem, and both wound up getting a tranny rebuild done. The second one was plain nasty, when they opened it up there was metal everywhere. I hope you have better luck than I have.
For Anthony, who was taken from our lives much too young. I love you honey, and I will always miss you.
~21 December 1973 - 29 September 2006~
Old 11-09-2009, 05:32 PM
merrick4's Avatar
I hope not too, but I've heard that if there was metal everywhere that you would hear a grinding noise. There is a chance that there is a warranty on this truck. Truck is in shop now, so I should know soon.
It was mentioned could be a sliding something or other.
Old 11-09-2009, 09:12 PM
merrick4's Avatar
Telling me it's some fork thing, seems to be a $400 fix. Thankfully.
Old 11-10-2009, 12:12 AM
Sabine's Avatar
good deal. One truck had no noise, the other did, so you never know. I am glad it was no big deal for you.
Old 11-10-2009, 11:05 PM
heavyhaulerss's Avatar
I dont know about other trucks , but mine has a magnetic plug. when I check every week or 2 on the trans fluid level, I look to see any metal attached to plug. if there was a lot of loose metal in trans, I would think it would show up there & give an indication before things get worse. if yours does not have one, I am sure you can buy one.
Old 11-10-2009, 11:14 PM
Kranky's Avatar
Broken detent spring or cracked shift fork?
Old 11-10-2009, 11:16 PM
Kranky's Avatar
The Eaton Fuller transmissions all have the magnetic filler plug, and a magnetic drain plug.
Old 11-11-2009, 03:16 AM
merrick4's Avatar
Looks much worse than first anticipated. They dropped somthing when fixing it and found a broken retaining something or other. Long story short I need a new transmission. On top of the new egr cooler for another truck I am having done and this is a costly week.
By the way, it's obvious I know nothing about mechanics but I went with someone to visually inspect the transmission on the floor, the thing that kills me is it was out of warranty by only 31 days.
Old 11-11-2009, 03:58 PM
this is a bad time to spend money on repairs. but ya have to do it. good luck recouping the out of pocket expense. hope you dont have nay more major prob's.
