fuel filter keeps plugging if temp >= 10F
Old 02-02-2008, 05:53 AM
I think the cold is just amplifying your air leak problem. The thicker fuel is harder to pump, therefore it sucks in more air instead of fuel.
Old 02-15-2008, 05:28 AM
Blind Driver's Avatar
Have you tried draining the water (if it is water) out of the fuel filter?
Old 02-16-2008, 10:35 AM
This may be entirely out of whack but I just had to change my water seperator. I is entirely seperate from the fuel filter on my truck . It was so clogged that I could not blow thru it . Now understand my truck is a class7 kodiak7500 but I just wonder if you have a seperate filter( water seperator) as well.
