Oil Sample Results
Old 10-11-2007, 12:41 PM
Papa Rick's Avatar
Default Oil Sample Results
Oil Sample was from Caterpillar in IL I believe.
Silver 0
Calcium 1315
Chromium 0
Copper 3
Iron 9
Lead 0
Magnesium 705
Molybdenum 42
Nickel 0
Phosphorus 911
Potassium 2
Silcon 3
Sodium 2
Tin 0
Vanadium 0
Zinc 1048
Soot 1
Oxidation 13
Nitration 7
Sulfation 17
Water, Antifreeze, Fuel, all Negative
Viscosity@100C 14.1
This looks good to me, am I missing something?
I did not have the oil changed until after the sample was pulled.
Old 10-11-2007, 11:37 PM
Rick, I get mine done at Blackstone Labs in FT Wayne, IN. Just take a sample myself with their pump kit (this way I KNOW it wasn't contaminated casue I did it) and mail it to them. Get an email about 2 days later with the report and a hard copy a few more days later. They give all the data, PLUS list out the current sample, several previous samples and your running average from all the samples........ AND they give a personal specific description of what is going on with your engine and oil - basically the tech breaks the data down into "plain english" for you. VERY NICE service.
http://www.blackstone-labs.com/
Old 10-17-2007, 07:07 PM
looks good. Also post at www.bobistheoilguy.com
Old 10-31-2007, 02:30 PM
Papa Rick's Avatar
Default Re: Oil Sample Results
Silver 0 1
Calcium 1315 1022
Chromium 0 1
Copper 3 2
Iron 9 11
Lead 0 1
Magnesium 705 581
Molybdenum 42 37
Nickel 0 0
Phosphorus 911 683
Potassium 2 2
Silcon 3 1
Sodium 2 2
Tin 0 0
Vanadium 0 0
Zinc 1048 817
Soot 1 3
Oxidation 13 15
Nitration 7 7
Sulfation 17 17
Water, Antifreeze, Fuel, all Negative Same All Negative
Viscosity@100C 14.1 13.5
First one with numbers were done 9/21/07 and not sure how many miles were on oil (prior to me buying the truck)
Second set of numbers were mine with 8,000 miles since oil change with Mobil Delvac.
Should I change it at 10,000 miles or go to 15,000 miles??
Old 10-31-2007, 03:30 PM
keep going.
Old 11-01-2007, 04:29 AM
Maniac's Avatar
Not only that, but you can talk to them on the phone and they offer suggestions and advice.
Been using Blackstone for around 10 years, won't go anywhere else
Old 11-10-2007, 12:53 PM
you really need to have multiple tests to evaluate what's going on inside as far as bearing wear and history of oil viscosity and breakdown.
