Steering gear
Old 08-19-2007, 02:03 AM
Part Time Dweller's Avatar
Here is the service manual for the gearbox. Look on pages 16-18 for the adjustments.
http://trucksteering.trwauto.com/files/HFB64-Intro.pdf
Old 08-19-2007, 02:33 AM
Hey part timer thanks for taking the time to post the links. I copied to my pc will look at them later. but thanks again.
Old 08-20-2007, 11:03 AM
Default Re: Steering gear
Originally Posted by sodbuster
I had a frightliner with a ross steering geare and was able to adjust the slack in the steering wheel. Now have Kenworth with a trw steering box and tried to adjust the slack and all it dose is make it harder to steer. the slack is still there. I had to try a happen medium so it was not to tight and had a little less slack. My question It feels like its harder to steer than it should be. is there a pressure adjustment to increase hyd pressure to the steering box, or maybe this one is just worn out??? it's really a pain in town when you have to wait till the last second to start your turn and really need to move the steering wheel in a hurry. It's so bad I even thought about one of those steerling balls, but I heard there illeagle in some states.
alan mentioned the fluid/whining... that's the obvious first check; fluid level and evident leaks - especially at the reservoir cover
if the steering gear preload is adjusted too tight, the steering will not "return" or center properly, therefore, when driving at road speed you would be always correcting the steering
to eliminate the linkage as a problem, try turning the steering right at the input shaft/u-joint... does the "lash" feel different when the engine is running?
...compare movement between input shaft and pitman arm
Old 08-21-2007, 02:23 AM
Thanks bob, and spiltshifter, I finally found the right manual on steering box. it's TAS 65. I going to check the spline and clamp like split said. and I never thought about haveing the engine running while checking the lash. I do think I have it adjusted to tight. Thanks for the comments, suggestions.
