Long term ideling
Old 06-14-2007, 07:24 PM
heavyhaulerss's Avatar
just got info off of cummins websight. say's idle at lowest prm's possible but never more than 800 i dont know how to put websight here.
Old 06-22-2007, 02:09 PM
Volvo motor does not need to be bumped up at all for idling. The manual and back of visor say the motor has an exhaust valve (i think) that maintains the temp. Yeah Volvo....
Old 06-22-2007, 10:39 PM
I bumped my high idle a bit simply to maintain better oil pressure.
Old 07-12-2007, 12:18 PM
Word of the wise, if you have recently swapped your turbo, DO NOT let your truck idle for excessive amounts of time. I can cause the thrust bearing in the turbo to fail and cause the turbo to leak oil. And if a shop detects that the truck has been idled over a given % of time via the ECM, they will deny warranty!
Old 07-12-2007, 01:38 PM
How do you bump the idle up?
1995 International 9400 w/DD 60 11.7
Old 07-12-2007, 04:36 PM
Just use the cruise control. Set the RPMs where you want and consider it bumped.
