Come to find out they never repaired the actual hole and fuel was getting between the tank and the band and would slowly seep at any pinhole.
That's cause they didn't do this:
I always air test the tank after welding and before re installation to be sure there are no pinholes in the welds.
You must air pressure test it and re-weld any spots that are leaking.
Than we had to move the tank back 6" so it fit in the saddlesproperly.
To fix that problem, I stated this:
This may make it tough to get the straps back on due to the slightly increased diameter of the tank in the repaired area, but you can then weld an extension on the T bolt on one end of the straps if necessary.
When you can keep the banded areas partially hidden under the tank straps, the repair is much less noticeable.
Whoever fixed your tank did it half assed.
When done right, and pressure tested, you don't need that epoxy BS.
