Fuel Econmony Hit in Winter
quote="allan5oh"]But one thing though... our diesels actually become more efficient when its colder out. Easiest way to tell is how much power it has. It's never going to inject "more" fuel at WOT+full boost. It always injects the same. If it pulls harder in winter, it's creating more horsepower with the same fuel. It becomes more efficient.
...i must look into that =) cooler air does increase efficiency up to a point... that's why most modern diesels use charge air cooling. but, keep in mind that any pre-'02 engine has plenty of excess air in the combustion chamber However, you're right when you compare the two one day to the next. I was talking overall, in winter the big difference is the extra friction and air resistance. I just got back from a trip, I fueled up with #2 in Minnesota. It's -35 with the windchill here. I would never run more then 50% #2 when it's this cold. you have that option... choosing your fuel blend? Hell, it even has that 2% biodiesel crap. No problems. Still not much of an improvement in fuel mileage compared to the Canadian fuel I had in there. I think I went from 5.8 to 6.5. But I also went from 42,000 lbs with the canadian fuel to empty and 16,000 with the #2. I also went from going with the wind to going against the wind. I think the #1 problem guys have with "gelling up" is water in the fuel. Almost all the time the guys are blaming the "crap american fuel" that they have to buy down south. I think it's from going from a very humid/warm climate to a very cold dry climate fast. The water condenses out of the air in the tanks, and collects on the inside of the tank. that's happening in everyday operation, i experience that very problem here; it is not the crap fuel, it's because the fuel blend has a lower cloud point. canadian summer fuel will freeze up in the winter as well Next time they fill up, trouble is a brewing! Don't you think it's funny how must trucks die shortly after fueling up, even with good Canadian fuel?[/quote water is usually a problem found at the pumps... RULE #1 - NEVER fuel your truck while the tanker is filling the inground tank!!!
Water and any diesel fuel or gasoline are immiscible...means they do not dissolve in each other. The water will separate and since it is more dense, will settle to the bottom of any container. That's why oil spills float on the ocean. bob is right, if you want water in your fuel, fill up while they are filling the underground tank>>>all that fuel getting dumped in will mix that water right into the fuel you pump. We bitch about paying $3/gal for diesel...how 'bout $3/gal for a goodly amount of water!!! The warm humid air to cold environment can play a part....but that is why you should not let a fuel tank sit empty (or very low)...less air space=less water laden air. It is also a good idea to drain any water accumulation you may get in your tanks occaisionally...less chance for it to be picked up into the fuel stream AND, there are little microorganisms which lieterally EAT diesel fuel but reside in the water and the fuel/water barrier. Their excrement resembles snotty bogies...and can gum up a filter real quick. So if you get your fuel from a joint that is "infected", if you will, your tanks can now be "infected" as well. There are bio-inhibitors out there that you add (just like anti-gel) to prevent or correct this. As for "gelling-up" water has nothing whatsoever to do with it. Diesel is "pure" in the chemical sense (neither is gasoline for that matter). It is a mixture of many long chain hydrocarbons roughly C9-C18 with a mixture flash point of >100F. Non-winterized deisel has a hight proportion of the longer chain molecules and the "gelling" to which you refer is actually the long chain molecules (specifically parrafin wax) separating and partially solidifying into wax. It'll still burn-in a candle...but will clog up a filter or fuel line right quick-like. The additives made to lower the CFPP (cold fuel pour point) or cloud point, if you will, are made to address this. So-called "winterized" fuel is also supposed to fix it...but sometimes does not, especially if the CFPP mix is say for 0F and you go where its -10F...oops. That's why its a good idea to dump some stuff in with every fill up...especially in winter or if you fill in a warmer clime and then go cold.
Tom
Yes I know "gelling" up has nothing to do with water, but it seems everyone points to "gelling" up as their problem, meanwhile gelling up has nothing to do with it. It's water, plain and simple.
As air gets colder, it gets thinner. EFI (fuel injection) compensates with more fuel to offset the lean mixture it normally uses at ambient temperature.
How many of you had cars with carbuerators? You probably remeber having to adjust it based on the season :wink: The EFI does that for us now in cars and trucks, even with altitude changes. In addition, other factors stated above (like winterblend), longer warm up times (where the truck hasn't gone into "open loop" yet) and many other drag down fuel economy in the winter. HTH
Mud, sweat, and gears
A few things bandit, don't take these the wrong way!
Air gets more dense when it's colder. The molecules are closer together, and the engines make more power and are more efficient. Not "thinner". Maybe you're thinking humidity? Trucks don't really have an open loop AFAIK. There's no oxygen sensor. It's much much more simple then a car EFI system. There's zero feedback. All it does is look at the rpm, the boost, the pedal position and decides from there. A diesel doesn't care about the air/fuel ratio.
quote="BanditsCousin"]As air gets colder, it gets thinner.
air density increases as temperature decreases, air density decreases (thinner) as altitude increases EFI (fuel injection) compensates with more fuel to offset the lean mixture it normally uses at ambient temperature. huh? ...are you talking about gasoline fuel injection and fuel trims? How many of you had cars with carbuerators? several... You probably remeber having to adjust it based on the season :wink: rarely ever... The EFI does that for us now in cars and trucks, even with altitude changes. In addition, other factors stated above (like winterblend), longer warm up times (where the truck hasn't gone into "open loop" yet) fuel injected gassers operate in open loop during engine warm-up. i.e., - STFTs are not adjusted based on O2 signal, because cold O2 sensors are inaccurate. many modern electronic controls use heated O2 sensors to eliminate cold-mode emissions and many other drag down fuel economy in the winter. HTH[/quote
quote="allan5oh"]A few things bandit, don't take these the wrong way!
Air gets more dense when it's colder. The molecules are closer together, and the engines make more power and are more efficient. Not "thinner". Maybe you're thinking humidity? Trucks don't really have an open loop AFAIK. There's no oxygen sensor. when a control system is in open loop, it simply indicates that a parameter is missing, and the ecm reverts to stored (approximated) info. in a fuel trim loop, the o2 sensor is ignored, and the ecm estimates the fuel/air ratio based on air flow (or pressure), engine speed, engine load, etc. a HEUI engine can also run in open loop; when the injection pressure sensor signal is lost, the ecm estimates injection rail pressure based on engine speed, fueling pulsewidth, and injection pressure regulator duty cycle It's much much more simple then a car EFI system. ... used to be ;0) There's zero feedback. did you know that an electronic diesel may set an engine code for "lower than expected boost pressure", "injector pulse width too short", or "turbo vane position does not match demand". each of these systems and more use feedback, either in the form of a sensor or calculated parameters All it does is look at the rpm, the boost, the pedal position and decides from there. A diesel doesn't care about the air/fuel ratio.[/quote it doesn't care about stoichiometric or lambda, but it does care about the fuel/air ratio... especially post-'02 H/D diesels when the manufacturers all took control of the air delivery to the combustion chamber
Yes, but it does not measure the a/f ratio. When I mean feedback, I mean strictly a/f ratio.
You're right, the new engines need to be run very precisely regarding a/f ratios. Too rich and PMs increase, too lean NOx increases. That's why cat uses variable valve timing, and all others use a variable geometry turbo.
quote="allan5oh"]Yes, but it does not measure the a/f ratio. When I mean feedback, I mean strictly a/f ratio.
agreed, when we discuss open loop, it would be assumed that we're talking about a fuel trim loop that is ignoring the o2 sensor (engine warm-up). i'm pretty certain that '07 engines do not measure exhaust gas content either You're right, the new engines need to be run very precisely regarding a/f ratios. Too rich and PMs increase, too lean NOx increases. That's why cat uses variable valve timing, and all others use a variable geometry turbo.[/quote
Bob H |
