rigmaster
depends on the truck. Some have a hand pump next to the fuel pump, some you can just fill the cannister and screw it back on (provided it hangs down and not upright). Check your engine manual for instructions.
REMEMBER, guns don't kill! It's the jealous husband that comes home early!
i had this same prob with mine called rigmaster and had them tell me how here it goes all you do is turn the lever by the fuel bowl to turn of the fuel then there are to screws on the top of the fuel bowl open the one on the right about half way now look at your fuel pump it is round and toward the middle it has a lever on it just flik it back and fourth about 15-20 times tighten the screw back in and turn the fuel back on and you are good to go a few times my rigmaster would start to run then die if this happens just repeat and it will fire right up. hope this helps if you have any more questions feel free to ask.
