when to put the radiator cover on?
Old 12-08-2006, 06:03 PM
engine heaters. Sort of like a block heater, only they run on diesel and circulate the coolant.
My espar works great, I've never plugged my truck in. It's started as cold as -40. Personally, I think they work better then block heaters.
Old 12-08-2006, 06:23 PM
I love ESPAR-it's the greatest thing since sliced bread.
No too hot or too cold in the bunk-JUST Right
Old 12-09-2006, 12:03 AM
Originally Posted by allan5oh
I got another one, when you're draining the coolant!
GLUG GLUG GLUG GLUG!
yeah, forgot that one... ;0)
Old 12-09-2006, 12:06 AM
Originally Posted by terrylamar
wabasto or espar????????????
also a cab heater for cold nights w/o idling a 15L powerplant
Old 12-14-2006, 01:12 PM
RockyMtnProDriver's Avatar
The only time I have ever used a winter front, is when it is both very cold and windy. And that is mostly just to keep the snow from blowing into the engine compartment.
Old 12-14-2006, 01:40 PM
classicxl's Avatar
have never had one on and never had any problems
Old 12-14-2006, 01:48 PM
SELDOM have I driven a truck that will maintain 175 or above when running m/t when it's cold out. So I use the winter front. What is the "ideal" operating temp?
Old 12-14-2006, 02:22 PM
Originally Posted by PhuzzyGnu
I just got back from a run to Cape Girardeau, MO over to Crane, IN and back to Houston. It was in the low teens with pretty good snow in Dale, IN when I woke up in the hotel room and went out to the truck (2007 Freightliner Columbia/14.0 Detroit). The truck started right up with no white smoke and was at driveable temp within 15 minutes. Once under way it stayed between 180-200*.
Winter fronts aren't for easy starting in the morning. The engine will be totally cold whether there's a front or not. However, if you have a wabasto or espar, the engine will definitely warm up quicker with the front. Especially when there's a stiff wind.
Winter fronts are for when it's REALLY cold to keep you warmer. They do work.
Also, they prevent a lot of sand and salt from hitting your rad. Everyone up here runs them.
Since I pulled my head out of my butt a while back I know that a winter front has no effect on cold starting.
My post was simply about a modern (2007) truck, cold starting, and operating temperature afterward- plus a little info from people more knowledgeable than I regarding a winterfront.
-p.
