Loose steering:
Originally Posted by Porchclimber
Everybody has pretty much got everything covered.
The only thing I could add is to check the bottom kingpins. It's very seldom that anybody jacks the weight off the front end when they grease. I find this makes a big difference because it lets grease get down into the kingpin and for kingpins you should use a graphite base grease because it will coat the bushing. Keep in mind - the grease goes through the bushing before the thrust bearing. You should use a NLGI #2 EP grease... IMO.
dawn If you mean by "loose" steering the truck tends to wander all over the road and follow the pavement seams, try raising your steer tire pressure. I normally run 110-115 cold in my steers, and seems to help a lot.
Even though I have one, I don't think having a Frieghtliner has much to do with it....JMHO! |
