detriot engine with a lot of blow by
Old 10-29-2006, 11:38 PM
I was in a truck stop this weekend talking to a guy with a Detroit Series 60 and he showed me his truck and he had a hose connected to the blow-by pipe under the engine and went into the exhaust stack.
Why would he do that
...I mean, what purpose could that possibly serve?
[/quote]Is this normal and OK to do this? [/quote]
No.
Old 10-29-2006, 11:47 PM
He did it so the smoke or steam wasn't coming out from under his truck and instead coming out the stack. I sort of thought that was obvious.
Old 10-30-2006, 12:09 AM
It is normal for a certain amount of crankcase gases (smoke, steam, whatever you want to call it) to come out of the breather tube. This problem is part of the '07 emissions for on-highway diesels, the '07 engines have a closed crankcase (no venting fumes).
If the gases are excessive... repair the problem. Actually, what he has done with the breather tube may actually compound the problem.
Under high exhaust flow, his crankcase will be under a high vaccuum
What SEEMS like a good repair... isn't always.
Old 06-10-2015, 06:36 PM
Hi, I have been reading through some of the history on the problems here and was wondering how things went in the end and if the problems were associated with the charge air cooler?
I work for a company that design and manufacture charge air coolers for large diesel engines called Vestas aircoil A/S in Denmark (www.vestas-aircoil.com), not so much truck engines but maybe they can advise if you have any problems.
They have a charge air cooler cleaning service facility in Denmark.
Old 06-24-2015, 01:28 AM
caboverjim's Avatar
Have you done an oil sample on this engine?
