Bad problem with steering/brakes.
Old 09-24-2006, 04:05 PM
Originally Posted by allan5oh
No to see if the spring bushings would clunk. I didn't ram them full speed, just enough to see if they would clunk.
OK :P
I was visualizing you going full throttle and hitting a pot hole to see what would happen. :P
Old 09-25-2006, 02:20 PM
To change the spring eye bushings you need to remove the spring.They can be changed in the truck but its usually easier to just take it out. the bushings are a bear to beat back in the spring eye and without the proper bushing driver its almost impossible to beat them in without destroying the new bushings. Good job for a spring shop
Old 09-25-2006, 02:46 PM
whenever I had a spring bushing go bad you could hear it. You hear anything or feel it when you Turn?
Old 09-25-2006, 06:48 PM
No I don't feel it when I turn, at least I don't think I do. What I can feel is the geometry changing when I hit bumps, etc..
There is a good spring shop around here, maybe I'll check it out.
