Closed Enforcement Cases Download Data
Investigation
Completion Date Investigation
Number Source of
Enforcement Violation
Section Number Violation Description Counts Settled Amount Settled
1 9/28/2001 IL-2001-97-US0832 Compliance Review 382.305(b)(1) Failing to do random alcohol test at applicable annual rate 7 $11,900.00
391.45(b)(1) Using a driver not medically reexamined each 24 months 1 $1,550.00
395.8(e) False reports of records of duty status 7 $2,660.00
Carrier Information Time and Location
RISINGER BROS TRANSFER INC
225 WEST COURTLAND STREET
MORTON, IL 61550
US DOT#: 244981 MC#: 172510
Report #: 00M1133194
Inspection Date: 7/29/2006
Start-End Time: 10:10 - 10:50
Inspection Level: 1-Full
Inspection Facility: Roadside
Post Crash Inspection: No
Vehicle Information
Unit Type Make State License # VIN #
1 TRUCK TRACTOR FRHT IL P582768 1FUYDWEB9XLA79578
2 SEMI-TRAILER UNK IL 112464ST NONE
Violations
Section Code Unit OOS Violation Category Violations Discovered
393.45(D) 1 N BRAKES, ALL OTHERS BRAKE CONNECTIONS WITH LEAKS/CONSTRICTIONS
393.75(A) 1 N TIRES Flat tire or fabric exposed
393.75(C) 1 N TIRES Tire-other tread depth less than 2/32 of inch
393.205(A) 2 Y WHEELS, STUDS, CLAMPS, ETC. Wheel/rim cracked or broken
393.75(C) 2 N TIRES Tire-other tread depth less than 2/32 of inch
396.3A1B 2 Y BRAKES, ALL OTHERS Brakes (general)
396.3A1BA 2 Y BRAKES, OUT OF ADJUSTMENT Brake-out of adjustment
392.16 D N SEAT BELT Failing to use seat belt while operating CMV
392.2 D N ALL OTHER DRIVER VIOLATIONS Local laws (general)
395.8(K)(2) D Y NO LOG BOOK,LOG NOT CURRENT,GENERAL LOG VIOLATIONS Driver failing to retain previous 7 days logs
Actualy there safety record is not that bad. Just some idiots like this
