Originally Posted by usedup
Winter fuel weighs 7.206 lbs per gallon. Use 153 gallons.... Problem solved.
Yup, I'm all set now and won't reach another scale for a while and when I do they either won't care about the extra weight or I'll get the green light. I was never over axle weight, just gross. I had them stack the load 5' from the rear and 8' from the front.
What my friend did was check with the other states on the regulations regarding over weight and the ones I'm passing through are all $25 per 1,000 pounds and NO out of service. New Jersey is one that does put you out of service. These states also allow the 400 extra weight on either the axle or gross with an APU installed.
No big deal, at least to me.
My Rismaster kept coming on last night like every 1/2 hour and when I woke up I realized why. My truck is all iced up and it's freaking freezing outside. The truck is about 75 degrees inside and no plans to to get out, that's for sure!
Lets see, it's 2:00am here but actually 1:00am for this time zone then I'll loose another hour getting to Colorado so everyone should still be asleep and I can just sneak right in!!
